20 Most Recent RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2 Questions & Answers
Not sure you'll find a wiring diagram for a Massey that has been customized, unless you create one yourself.
You can try your local authorized service center or contact online here: http://www.masseyferguson.us/about-us/contact-us.html
RTO... | Answered on Feb 09, 2018
It is possible to have the solenoid go bad but not while the tractor is running as it is only used to engage the starter. It sounds like the wires to the starter is shorted out. I would run a hot wire to the solenoid from the battery to the solenoid and see if it will start. Just be sure everything is grounded. If the ground cable on the battery is ok you should not have a problem with running a hot wire to the solenoid. Just touch the hot wire to the starter and then release it when the starter engages. Hope this helps.
RTO... | Answered on Apr 16, 2017
check your ground to the starter, if thats ok try tapping on the outside of starter body while trying to start engine, the starter may have a dead short in it
RTO... | Answered on May 30, 2015
contact the manufacturer on line for any available pdf downloads.
try e-bay for manuals.
RTO... | Answered on May 05, 2015
If you're not having any electrical issues then Check the governor.
RTO... | Answered on Mar 28, 2015
Sounds like a bad ignition condenser. Many nowadys aren't worth spit, and you may wind up going through a few until you find a good one.
RTO... | Answered on Feb 22, 2015
The hydraulic control valve for the hitch is not opening correctly, take it apart and clean it
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Check out our Resource pages at www.fergusontractors.org and if that doesn't give you what you need email our Ferguson technical advisor, Robert Sybrandy at [email protected]
RTO... | Answered on Feb 11, 2015
RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2 Logo
266 questions posted
Top RTO Toys Experts
Marvin
Marvin
ray gallant
Bill Boyd
Are you a RTO Toy Expert? Answer questions, earn points and help others
View Most Popular
RTO Toys
  • RTO Toys
Most Popular Question
farmall 140 insttalled new solenoid
  • Toys
