20 Most Recent RTO Pit Bikes Questions & Answers
check the cable leading to spark plug and also check whether any blocking in the spark plug
RTO Pit Bikes | Answered on Jul 03, 2013
did u tryand clean the carb and air filter if that dont work try and take the bowl off the bottom of the carb and see if the little pin for the floats are stickin and clean everything while u r there and see how that work should fix the prob
RTO Pit Bikes | Answered on Oct 30, 2012
either it is not getting enough fuel or it is getting too much, the adjustment you have made is wrong, go back to the owners manual and recheck the setting.
RTO Pit Bikes | Answered on Nov 03, 2011
you to adjust the clutch cable
RTO Pit Bikes | Answered on Aug 18, 2011
remove the alternater cover and check all the wires are intact behind there
RTO Pit Bikes | Answered on Mar 08, 2011
Try unpluging the cutouts.they are usally on 2-3 places on these bikes ,brakes,also check the fuse that is on the red wire comming off the battery it will be blown or end of fuse holder will be pushed in and not touching the fuse.
RTO Pit Bikes | Answered on Jun 25, 2010
If you have spark them it must be gas. eather no gas or to much gas. Put it on chock, be sure the shut off valve is in on position.Now crank it over a few times , if it wont fire. Check the plug , is it wet or dry .If its wet then it may be flooded and needs to dry out and air out the cylinder.Try starting when dry. If its dry try putting a 1/2 oz of gas into the spark plug hole. replace the plug and turn it over . This will get them to fire up. Good luck DFD
RTO Pit Bikes | Answered on Apr 13, 2010
your spring might have broke on your throttle needle take apart have a look
RTO Pit Bikes | Answered on Feb 03, 2010
u will need a puller tool
they just sound like wires for the lights speedo ect.not why bike aint running.
change spark plug,cdi unit,strator or coil lead
The motor has to be pulled apart and I would not advise doing it yourself unless you have a lot of mechanical experience. EG: if the bore is damaged it will have to be honed and resleved, this is only one aspect of changing the piston. You also have to make sure all goes back together properly or you timing will be out and you may do more damage. Hope this helps.
RTO Pit Bikes | Answered on Oct 30, 2009
the oil filter is above the oil plug, you have to remove the clutch cover etc.. its just a piece of fine wire mesh
RTO Pit Bikes | Answered on Oct 03, 2009
RTO Pit Bikes Logo
37 questions posted
Top RTO Toys Experts
Marvin
Marvin
ray gallant
Bill Boyd
Are you a RTO Toy Expert? Answer questions, earn points and help others
View Most Popular
RTO Toys
  • RTO Toys
Most Popular Question
pit bike 125 its not starting wot ever
  • Toys
