20 Most Recent Razor E300s Electric Scooter With Seat Questions & Answers
it will run slow for 40 mins at a slow speed, after 15 mins of running fast, the batteries get too hot
Razor E300s ... | Answered on May 21, 2017
I posted a similar issue about the same scooter. If you do replace the batteries and still experience the same issue, check the wiring for loose wires and possibly replace the fuse.
After replacing the fuse and connecting wires, my scooter doesn't pop the fues with every use anymore.
http://www.fixya.com/support/t7752702-ride_scooter_turns_off
Razor E300s ... | Answered on Nov 02, 2014
Note the charger doesn't turn itself off. It will only signal batteries are charged. You can overcharge these batteries by leaving them on the charger for too long. Suggested by retailer is two hours maximum.
Any case, Jackson Mack is correct on all counts there.
If the light is green on the charger, and the scooter still doesn't go, there might be some other issue besides the batteries themselves like loose wiring, fuse switch, etc.
Razor E300s ... | Answered on Apr 30, 2014
I posted a simliar question. I ended up taking my scooter to a battery store that is licensed to work on razor scooters. They ulitmately concluded the wires to the popup fuse itself were loose. They replaced the popup fuse as well just incase. I have now been using the scooter without the fuse popping every 50-100 feet.
Razor E300s ... | Answered on Oct 30, 2013
Hey oscar suarez
Check out this manual and go to Page 13. There you will step by step directions on how to replace a Rear Wheel
Good Luck
Razor E300s ... | Answered on Jul 29, 2012
THE CONNECTION BETWEN THE BATT.AND MOTOR IS LOSE
Razor E300s ... | Answered on Aug 06, 2009
Hi there, charging normally takes approx. 16 hours. Do not leave the appliance connected to the mains for more than 24 hours.
I have included a link for the user manual for this product.
Razor Toys | Answered on Apr 18, 2020
so what had been hapening is that it could die depending if it was the battery that could aftfect with this. 24 volt battery, and can be ridden for up to 45 minutes after battery charging. The charge time recommended for this Razor electric scooter is about 10-12 hours after each use.
Razor Toys | Answered on Jan 02, 2020
The Razor 13013290 Air Scooter's frame is made from aluminum steel which is strengthening strongly. This is why you can use the scooter for a long time.Click here for more details complete Razor 13013290 Air Scooter review
Razor Toys | Answered on Apr 10, 2018
Hello
Before you change the battery check thoroughly all wires and all connections!!!!
Razor Toys | Answered on Nov 26, 2017
Razor E300s  Electric Scooter With Seat Logo
9 questions posted
Top Razor Toys Experts
ROB
Andrew Taylor
Andrew Taylor
Dennis Key
Dennis Key
Are you a Razor Toy Expert? Answer questions, earn points and help others
View Most Popular
Razor Toys
  • Razor Toys
Most Popular Question
e300 runs 15 minutes gets slow rests
  • Toys
