20 Most Recent Buck Pontiac G6 2005-2007 05 Stereo/radio Wire Harness Plug Questions & Answers
Where can i find the rheostat resistor on a G6
Are you shure it has to do with the resistor, All the resistor does is controls,The different fan speeds, If you are geting no power to it, Have you check if the fuse blew for it? Or the relay for it could be defective, Or the blower motor might be burn,t out,
11/6/2012 12:53:44 AM • Buck Pontiac G6... • Answered on Nov 06, 2012
What color wire is the ignition switch?
According to this forum it's pink.
Hope this helps
Ray
3/7/2011 4:50:00 AM • Buck Pontiac G6... • Answered on Mar 07, 2011
My g6 2007 does not have the original stereo
I would call all of the salvage yards until you are able to locate one where they have your car. Best to start as close to home as possible because you are likely going to have to go and pull it off. The Dallas County Auto Salvage yard on MacArthur will pull it for you, all you got to do is pick it up. They may mail it. I am not for sure about the mail thing though.
2/13/2011 3:39:25 AM • Buck Pontiac G6... • Answered on Feb 13, 2011
2answers
Pontiac G6 please help
newer cars come with an amp built in so mak esure u hook up the amp wire it may end up plugging into the power ant. or amp wire
2/2/2011 11:13:31 PM • Buck Pontiac G6... • Answered on Feb 02, 2011
I want to replace my Pontiac G6 radio. But I want
There is a kit from Metra called the Metra 99-3303 kit that takes the double din area of the stock stereo and converts it into an info center/single din. Cost is about $123 on ebay.
11/21/2010 2:15:53 PM • Buck Pontiac G6... • Answered on Nov 21, 2010
2007 Pontiac G6 rem wire
This factory stereo does not provide a switched 12 volt source. You will have to go to an accessory power source in the vehicle. That's what the extended red wire is for.
9/20/2010 12:06:16 PM • Buck Pontiac G6... • Answered on Sep 20, 2010
Replaced the bat in 2007 g6 now the radio will not
If it is a factory radio,whenever you remove the battery the radio goes into a locked mode.You need to call a Buick dealer to get the unlock code and have them tell you how to do it.Write down the code for the future possibilities too.Good luck! Greg
8/28/2010 5:57:27 PM • Buck Pontiac G6... • Answered on Aug 28, 2010
05 G6 radio reads cd changer errror
Im having the same issue ..and actually seen this issue on alot of message board or websites..starting to think its a manufacture issue
5/26/2010 2:55:53 AM • Buck Pontiac G6... • Answered on May 26, 2010
Radio wont shut off
The power and ignition wires are crossed there are 2 wires that are important one is a memory wire this keeps your presets and the clocked stored this should have power on it at all times, sometimes the wire color is yellow blue, but never red. And then there the second wire this is only powered when the key gets turned this wire is red always red. My advice to you would be see what wire on the back of your radio is getting power all the time and switch it with the wire that only has power with the key on good luck
4/18/2010 6:03:07 AM • Buck Pontiac G6... • Answered on Apr 18, 2010
Can i put a after market cd player in my 2005 g6?
absolutely just make sure u get the right faceplate an wireharness
12/12/2009 8:26:39 PM • Buck Pontiac G6... • Answered on Dec 12, 2009
Radio just quit playing ... was fine Friday on the
If aftermarket check the fuse on the radio, if factory its a good chance your radio has gone bad
11/5/2009 11:51:03 PM • Buck Pontiac G6... • Answered on Nov 05, 2009
No sounds from stereo
sounds like that is the problem i think that you need a special harness go to this website: metraonline.com and look up your vehicle you should be able to find the harness at bestbuy or a car stereo shop not sure how much it could be. May be expensive.....
4/2/2009 5:14:08 PM • Buck Pontiac G6... • Answered on Apr 02, 2009
0answers
Buck Pontiac G6 2005-2007 05 Stereo/radio Wire Harness Plug Logo
Popular Tags
29 questions posted
Top Buck Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you a Buck Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Buck Car Audio & Video
Most Popular Question
g6 2007 not original stereo
  • Car Audio & Video
