20 Most Recent BMW 02+ 3 5 X5 M3 Series Car Radio Wiring Harness Wire Questions & Answers
its seem life u have wrong connection
BMW 02+ 3 5 X5... | Answered on Mar 05, 2019
Did you try pressing the CDC eject button and keep pressing it until it ejects the CDC Box?
BMW 02+ 3 5 X5... | Answered on Dec 09, 2010
In that vehicle there is a factory amp. It will power up with the White wire in the factory harness. Hook the amp out wire from the aftermarket unit to this white wire. It also controls your antenna.
BMW 02+ 3 5 X5... | Answered on Aug 24, 2010
Will require specialist advice
Try here
www.ukbookshelf.co.uk
Mention this forum
BMW 02+ 3 5 X5... | Answered on Jul 24, 2010
disoncnect battery, then reconnect. this will reset computer.
BMW 02+ 3 5 X5... | Answered on May 16, 2010
check behind the head unit if the arial cable is pluged in or damaged, then see if u cn follow the wire to the rear of the vehicle far damage, also check of its a motorised arial make sure it extends. beware if its a factory unit like Becker, ull need a security code if the power is disconnected that you can only get from BMW
BMW 02+ 3 5 X5... | Answered on May 03, 2010
You will need a small test lamp (its quicker) and a pre wired socket would be great. Terminals are numbered from #1 to #7 .. Ter 1 LH indicator , Ter 2 For lamp Ter 3 EARTH (most important terminal ) Ter 4 RH indicator, Ter 5 LH tail lamp , Ter ^ brake light , Ter 7 (in middle) RH tail lamp.
BMW 02+ 3 5 X5... | Answered on Apr 11, 2010
Quote the radio make + model plus all the letters+numbers on the radio casing
BMW 02+ 3 5 X5... | Answered on Apr 01, 2010
Did the battery get disconnected? if so you need a code to get it to work. you will need to go to the dealer or i think some wab sites will get the code for you for like $30 but it may be a scam. the dealer can get it with the vin number or just the key. (i think)
not unless you find someone willing to work on it that really knows what they are doing.
if you remove the deck,and take off the front panel,there is a printed circuit board with some 4 pin switches,surface mount on that board.
if you replace the switches it will work fine.
BMW 02+ 3 5 X5... | Answered on Jan 13, 2010
Hello rbs845,
Most vehicle audio integrated phones use a ground on a specific wire from the receiver to activate the "mute" function. If the wire contacts other wires or shorts to ground, it can cause the receiver to signal an incoming call or mute. Without the exact make and model of the receiver, it's not possible to point you to a specific wire color to look for. I'd make sure that ALL wires that are not used are securely insulated and kept from touching other wires or metal behind the dash.
Hope this helps.
BMW 02+ 3 5 X5... | Answered on Sep 25, 2009
Every car and every stereo has a different plug and socket arrangement. Your best bet is to google search Car Audio in your area, and get a shop to take a look. They will be able to source the exact adaptor you need, with no mistakes...
Hope this helps,
M3ODQ
BMW 02+ 3 5 X5... | Answered on Feb 11, 2009
I Just bout an r32 mk5 golf 4motion and it has eonon unit. The touch screen not working I can not move up or down the icons to turn blue tooth on. Or anything cant select between USB stick and sd card and not showing any maps the touchscreen not in any operation at all. Has anyone had this issue
BMW Car Audio &... | Answered on Jun 05, 2019
what kind of accessories
BMW Car Audio &... | Answered on Mar 05, 2019
BMW 02+ 3 5 X5 M3 Series Car Radio Wiring Harness Wire Logo
23 questions posted
Top BMW Car Audio & Video Experts
Colin Stickland
Colin Stickland
Ivgsoft Ivgsoft
Are you a BMW Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • BMW Car Audio & Video
Most Popular Question
2003 x5 three buttons stereo
  • Car Audio & Video
