20 Most Recent
Garmin Edge 510 Cycling Computer Performance Bundle Questions & Answers
I bought a used HRM1G on Amazon. Can I pair it with my iPhone by bluetooth, using the Garmin connect app? It came without a manual.
Yes, it is possible to pair your HRM1G heart rate monitor with your iPhone using Bluetooth and the Garmin Connect app. Here's how you can do it:
- Make sure your HRM1G is turned on and within range of your iPhone.
- Open the Garmin Connect app on your iPhone.
- Tap the menu icon in the top left corner of the app, then tap "Devices."
- Tap "Add Device" and follow the on-screen instructions to pair your HRM1G with your iPhone.
- Once the HRM1G is paired with your iPhone, it should appear in the list of devices in the Garmin Connect app.
- To use the HRM1G with the Garmin Connect app, simply tap the "Start" button in the app to begin tracking your heart rate. The app should display your heart rate in real-time as you exercise.
I hope this helps! Let me know if you have any questions or if you need further assistance.
Tmobile network unlock code
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
Please help me to unlock my phone garmin asus.IMEI: 357355039167371. with serial no.A5AAA
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000iF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
