20 Most Recent Metra Ford F 150 Truck 1996 Up Questions & Answers
Thomas,
Your problem might be in the throttle body or TPS. Check it with a multimeter. Slowly move the throttle and watch the meter for erratic movement. If it looks good clean the body and reassemble. Be sure to check the CPS (crankshaft position sensor) if your car has one. I hope this helps, Ray
Metra Ford F 150... | Answered on Mar 06, 2015
You won't know if the water is moving unless you removed the thermostat, the thermostat will remain closed till the car heats up and then water will flow through your raditor.
Water pumps always spin! Unless you belt has come off it will be spinning, What happens to water pumps is they will end up with a bad bearing and will get hot. There is a small hole in the bottom by the bearing that will eventually let the water leak out to keep that bearing from melting and seizing up. If you are not hearing any grinding noises or squealing or water leaking your pump is fine.
Metra Ford F 150... | Answered on Nov 16, 2014
The idea of the clutch fan is that when your vehicle gets hot the clutch is designed to start gripping the fan blade more to allow the fan to spin faster as the temperature risies. Then when you are moving fast the clutch will disengage and free wheel letting the air move freely past it. The fan would actually be moving slower than the air rushing into the engine compartment from the speed of the car and would be blocking the flow.
The most important part of the clutch fan that makes it work properly is the Shroud, it attaches to the radiator and it directs the heat toward the clutch properly. Without the correct shroud the clutch is useless and will not function properly.
if you look under the driver side dash follow the brake pedal up and you will find a plastic actuator some time these stick its cheaper just to buy a new one as used could have the same problem
Metra Ford F 150... | Answered on May 20, 2014
Sounds like you have a bad IAC. Idle Air Control Valve.
Metra Ford F 150... | Answered on Sep 08, 2010
check in line fuel rial pup
Metra Ford F 150... | Answered on Mar 29, 2010
Check for computer problem, find someone that have a truck like yours and switch computers, check for ecu good ground and try to erase the ecu and reprogram it back. MOst garages have a ecu reprogram tool.
good luck.
replace the nuetral safety switch on the transmission.
Metra Ford F 150... | Answered on Aug 13, 2009
is the mounting broken?look at the bottom.you may need to make a bracket for it.if it leaking at the bottom it has to be de greased and then epoxy to the motor
Metra Ford F 150... | Answered on Jul 11, 2009
Sounds like a bad or broken rocker(s)
Metra Ford F 150... | Answered on Jul 08, 2009
get a continuity checker for 10 dollars and check the ground on the light where it touches the body the light might not have sufficent gound. for the light to light. ( basic electrical knowledge)
IF U HAVE 2 DIFFERENT GAS TANKS BOTH OF THEM HAVE THERE OWN FUEL PUMPS, WHICH MEANS IT WENT BAD...........
Metra Ford F 150... | Answered on Mar 20, 2009
It’s a ground, if your amp still won’t turn on after u finished installing Then use brown one as a ground and ground it to the same one as your amplifier.
Metra Car Audio... | Answered on Jan 21, 2019
You need to make sure the amp turn on lead is connected... its blue with a white stripe
Metra Car Audio... | Answered on Dec 31, 2017
Need more information. Are you talking about close to the camera or at the end that connects to the radio/display?
Metra Car Audio... | Answered on Nov 06, 2016
Metra Ford F 150 Truck 1996 Up Logo
21 questions posted
Top Metra Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
jdthefixer
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Metra Car Audio & Video
Most Popular Question
start 1997 f150 6cyl out park
  • Car Audio & Video
