20 Most Recent Metra 95 96 Chevy Truck Questions & Answers
Venom was a product line from directed electronics inc. I would suggest contacting them as they could advise what model keypad would work as well as if they have any available anymore.
Metra 95 96... | Answered on Oct 25, 2016
Timing is off, advance the time 6 to 8 degrees is normal for 350 sbc
Metra 95 96... | Answered on Sep 03, 2014
Check and clean grounds make sure there are no crack insulators or fractured wire, if there is cut, solder. Reduction in wire surface area causes resistance, which causes fuses to heat up and pop
Take the oil filter out. Get a screw in plug.
Metra 95 96... | Answered on May 25, 2011
Fairly easy on driver's side as they are very visible. Just unplug the harness for each plug and set it above the plug. Use a deep well socket that fits the plug (use a new one to ensure you have the proper size) and remove the old ones. Apply some anti-seize to the threads of the new plugs before youput them in. This will help with removal in the future. Install all the new plugs and re-connect the plugs to the harness.
On the passenger side, you will need to remove the tire and the inner fender skirt to reach the back 2 plugs. Be sure you block the vehicle to prevent it from falling and do not rely on just the jack. Follow the same procedure as above and it should fire right up.
**Be sure to check each old plug to ensure that none of the tips melted or broke off in the cyclinder. It will be obvious if one is broke.**
Metra 95 96... | Answered on May 22, 2011
If your truck is shaking when you apply the break. There is a good chance that your rotors are warped. If you take them off, and take them to a shop that cuts rotors. They may be able to fix them for you. If not they will need replaced
Metra 95 96... | Answered on Jan 15, 2011
some of these 1500 series trucks had bad computer flashing, locate a used computer from the local scrap yard and try it. make sure it has the same engine and options on the truck. if not then change the control module, this is what gives the plugs and coils a spark signal.
Metra 95 96... | Answered on Jan 03, 2011
how do i set the timng on a 97 chevy 1/2 ton using a timing light
Metra 95 96... | Answered on Jun 16, 2010
Hi and thank you for using fixya. See below for instructions in removing evaporator.
Tools needed.
AC freon holding tank and extractor metal torch new evaporator freon to put back in the system
1- empty the system and save the gas inside it will deplete the ozone layer 2--take out evaporator by cutting on both end with the torch 3- put new evaporator back by uniting with blow torch both ends. 4-put your gas back on
good luck
Metra 95 96... | Answered on May 25, 2010
there is a port on the back of the throttle body, near the bottom, directly between the injectors.
Metra 95 96... | Answered on Oct 01, 2009
Have you changed your fuel filter? Are you sure your don't have a bad plug or wire? Is it fuel injected? Checked fuel pressure?
Metra 95 96... | Answered on Aug 18, 2009
there is no way to loosen the belt in that chevy. it is a serpentine belt system with a belt tensioner that keeps the correct tension on the belt. check the belt and all the pulleys for wear. if the belt and pulley are in good shape i would suggest changing the belt tensioner.
Metra 95 96... | Answered on Jul 16, 2009
It’s a ground, if your amp still won’t turn on after u finished installing Then use brown one as a ground and ground it to the same one as your amplifier.
Metra Car Audio... | Answered on Jan 21, 2019
You need to make sure the amp turn on lead is connected... its blue with a white stripe
Metra Car Audio... | Answered on Dec 31, 2017
Need more information. Are you talking about close to the camera or at the end that connects to the radio/display?
Metra Car Audio... | Answered on Nov 06, 2016
Metra 95 96 Chevy Truck Logo
16 questions posted
Top Metra Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
jdthefixer
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Metra Car Audio & Video
Most Popular Question
1992 chev
  • Car Audio & Video
