I need the color code for a Ford audio system j v a l l o v l 18 c8070 ABC real number 0 27747 I'm getting aggravated because you're not giving me no color code list
Believe me that is only the start of your problems, the unit is one of the most disappointing things I have ever bought, it doesn't work using a memory stick either using the buttons or the app it needs a complete rewrite of both firmware and software and Scosche tell me they are not rewriting either so tough luck!! Check other forums for other opinions but whatever you do don't buy it.
Most likely the amplifier you have hooked up to that fuse position is defective and causing the fuse to blow. Or you have a short in the powerline somewhere. Disconnect the power wire from the amplifier, tape up the end so it won't short out to anything. Replace the fuse, if it doesn't blow then you will need to get the amp checked, if it does blow, then you have a short somewhere along your power wire.
