20 Most Recent Scosche Industries Scosche Gm05b Wiring Harness for 2000&Up Chevy Metro/Prizm/Tracker/Venture Questions & Answers
3answers
Where is the fuses located in a 2001 chevy prizm?
open the hood.on the left side there is a fuse box and also in the lower left of the dash underneath there is a cover and fuses inside.
your car is built by united auto works in fresno calif. and is the same as a 2001 toyota corolla if you need parts.just the body panels lights etc are different.
2/16/2020 2:21:54 PM • Scosche... • Answered on Feb 16, 2020
I cannot find the
use your handy dandy test light. it's the easyest way. pretty cheap at autozone. remember, you will have one at 12volts constant, if you can't find one on the connector, tap your cigarette lighter. next turn on the key and find the switched 12volts and make sure it's the right one by turning power on and off. turn the lights on and off just to make sure you didn't get the illumination wire.
4/1/2010 9:51:39 AM • Scosche... • Answered on Apr 01, 2010
TRYING TOO BY PASS ANTI-THIEF DEVICE ON 2000 CHEVY
If you're talking about the alarm, it's in the programming. There are 4 modes, depending on your model.
Mode 2 has delayed illumination, auto door lock, last door close/lockout detterent
Mode 3 has all those plus remote driver's door unock
Mode 4 adds the remote lock/unlock confirmation, content theft, content theft arming/disarming
Enter progam mode by
1. remove the BCM PRGRM fuse from the instrument panel fuse block.
2. Close the driver's door.
3. Turn the ignition key towards you, to ACC
4. Count the number of chimes you hear. You will hear two to four chimes depending on the features your vehicle is equipped with.
You are now in program mode...
With the content theft-deterrent system, if anyone damages or enters your vehicle whie the system is armed, the horn will shound and your parking lamps will flash for two minutes. The content theft shock sensor detects if anyone damages your vehicle. The shock sensors sensitivity can be adjusted by your dealer if more or less sensitivity is desired.
Mode 1: damage detection w/ reduced sensitivity
Mode 2: damage detection off (alarm only sounds when door is opened)
mode 3: feature off
mode 4: damage detection with Normal sensitivity
To change modes, enter the program mode, turn the parking lamps on and off, count the number of chimes you hear, that is which mode your vehicle is in. you can change the mode by turning the parking lamps on and then off again. Repeart turning lamps on/off untill you hear the numer of chimes you want.
The mode is now set, you can either exit, or program another feature.
To exit, turn thekey from acc to off and put the BCM PRGRM fuse back.
1/7/2010 1:07:15 PM • Scosche... • Answered on Jan 07, 2010
Where can i find the fuse for the radio on a 1998
If its a factory radio, the fuse will be in the fuse box (typically located on the left side panel of the dash or under the steering column)
If its an aftermarket unit there will be an in-line fuse on the units power lead(s)
Aduz
3/29/2009 4:29:01 AM • Scosche... • Answered on Mar 29, 2009
FORD AUDIO SYSTEM jbl fovf-18C807-AB wiring diagram
I need the color code for a Ford audio system j v a l l o v l 18 c8070 ABC real number 0 27747 I'm getting aggravated because you're not giving me no color code list
4/18/2022 6:12:17 AM • Scosche... • Answered on Apr 18, 2022
Are you able to tell me the year and modle the amp came out of. Cannot seem to find this part number with Ford so this would help........
11/17/2015 11:45:04 PM • Scosche... • Answered on Nov 17, 2015
Scosche SCDBTA60A when hooked up to the wiring in my truck will not power on the head come on when first plugged in and then shuts off
Believe me that is only the start of your problems, the unit is one of the most disappointing things I have ever bought, it doesn't work using a memory stick either using the buttons or the app it needs a complete rewrite of both firmware and software and Scosche tell me they are not rewriting either so tough luck!! Check other forums for other opinions but whatever you do don't buy it.
1/15/2015 12:47:34 AM • Scosche... • Answered on Jan 15, 2015
Hey i have a scosche in-line fuse block i purchased. I haven't had any problems until recently. My fuse fried. So i bought more and went to replace it and every fuse i try instantly fries. i cant seem
Most likely the amplifier you have hooked up to that fuse position is defective and causing the fuse to blow. Or you have a short in the powerline somewhere. Disconnect the power wire from the amplifier, tape up the end so it won't short out to anything. Replace the fuse, if it doesn't blow then you will need to get the amp checked, if it does blow, then you have a short somewhere along your power wire.
7/8/2014 6:21:45 PM • Scosche... • Answered on Jul 08, 2014
0answers
0answers
0answers
0answers
0answers
0answers
Pioneer gm 3000
Be the first to answer 2/3/2014 6:51:33 PM • Scosche... • Posted on Feb 03, 2014Be the first to answer
0answers
Scosche Industries Scosche Gm05b Wiring Harness for 2000&Up Chevy Metro/Prizm/Tracker/Venture Logo
14 questions posted
Top Scosche Industries Car Audio & Video Experts
xxxxxx xxx
Are you a Scosche Industries Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Scosche Industries Car Audio & Video
Most Popular Question
fuses located in 2001 chevy prizm
  • Car Audio & Video
