20 Most Recent
LG enV2 VX9100 Cell Phone Car Charger Questions & Answers
I connect the charger to my lg env2 and nothing
It is most likely the charger port. They are cheap to purchase on E-bay, but require some knowledge of soldering to install it. What you could try is bending your charging wire back and forth, giving it a few seconds to respond. It may come on, then you have to hold the wire in that place while it charges. You can use a rubber band for this.
Software update on Env2
One of the biggest problems with this phone is the OK button not working, and the front keypad doing the same eventually. Everyone I know with this phone has the EXACT same problem.
LG enV 2 not turning back on
If possible take it into your cell providers store and ask them to check it. They should be able to do a battery test and a software check for free of charge. If they are no help check the brass contacts on both your battery and phone. They might be making intermittent contact or be corroded. Also check for water damage. There should be a small sticker, if its pink its water damage. It could also be a defective battery, but don't buy one. Try to find someone that has one and borrow it to test. Good Luck
Lg fb163-how to add bluetoth function
To add Bluetooth functionality to your LG FB163, you can use a Bluetooth adapter that is compatible with the device. Ensure that the adapter you choose is compatible with the FB163 model. Once you have the adapter, follow the instructions provided with it to connect it to your FB163 system.
To connect your Android phone to the FB163, you'll need a compatible cable. Typically, you would use an auxiliary (AUX) cable with a 3.5mm jack on both ends. Plug one end into the headphone jack of your Android phone and the other end into the AUX input port on the FB163 system. Then, select the AUX input mode on the FB163 to hear the audio from your phone through system.
How can I hatd factory hard reset my LG 265 if I don't have my pin # nomore or forgot it .
- Turn the phone off.
- Press and hold the Power/Lock key (on the right side of the phone) and the Down Volume key (on the left side of the phone) at the same time.
- When the Factory data reset screen appears, release both of the keys.
- Use the Volume keys to highlight Factory data reset, then press the Power/Lock key to confirm.
- Use the Volume keys to highlight Yes, then press the Power/Lock key to confirm one more time.
- Your phone will perform a factory reset.
