20 Most Recent
LG PCMICROSTORE Brand DARE VX9700 VX-9700 Solid Green Snap-On Case Cover with Removable Swivel Belt Clip Questions & Answers
My lg dare is locked
Not without her finding out you were snooping in her phone - Check Howard forums, Bitpim may do it. Hacking will void the warranty.
Keypad sound shutoff
If you go into settings there should be keyboard settings;there you should find the silence button. If not go into sounds and there should be a silence for the keyboard...hope this helps!
UNLOCK CELL PHONE!
Unlocking the LG Dare VX9700 is quite difficult unfortunately. Since Verizon phones are CDMA and not GSM, you will need some advanced unlocking software, which you can learn more about from this
phone guide.
Lg 9700 doesn't recognize jpeg pics on the memory
if you have added these from a computer you actually need to make sure that you are placing them in the folder called "my_pix" that should have been added to the sd card after you formatted it within the phone
they cannot just be randomly stored on the card
if you do not see a folder, try taking a picture on the phone and then moving it from the phone to the card. the folders will automatically be created then
Can't find the sd card on the phone
Did the phone come with a memory card? Did you or somebody else put in the card? There are only 2 placec that a memory card is found in a phone- either under or near the battery, or in a slt on the outside left or right of the case. If you can't find it, maybe you don't have one.
Lg fb163-how to add bluetoth function
To add Bluetooth functionality to your LG FB163, you can use a Bluetooth adapter that is compatible with the device. Ensure that the adapter you choose is compatible with the FB163 model. Once you have the adapter, follow the instructions provided with it to connect it to your FB163 system.
To connect your Android phone to the FB163, you'll need a compatible cable. Typically, you would use an auxiliary (AUX) cable with a 3.5mm jack on both ends. Plug one end into the headphone jack of your Android phone and the other end into the AUX input port on the FB163 system. Then, select the AUX input mode on the FB163 to hear the audio from your phone through system.
How can I hatd factory hard reset my LG 265 if I don't have my pin # nomore or forgot it .
- Turn the phone off.
- Press and hold the Power/Lock key (on the right side of the phone) and the Down Volume key (on the left side of the phone) at the same time.
- When the Factory data reset screen appears, release both of the keys.
- Use the Volume keys to highlight Factory data reset, then press the Power/Lock key to confirm.
- Use the Volume keys to highlight Yes, then press the Power/Lock key to confirm one more time.
- Your phone will perform a factory reset.
Im locked out of my
WARNING : Performing a hard reset will remove ALL data including the Google account, system data, application data, application settings, and downloaded applications.
- With the phone off, press and hold the Home key, Volume Down key and Power button. When the LG logo appears, release only the Power button.
- Release the Home key and Volume Down key when the Android icon appears.
- Follow the on-screen instructions.
