20 Most Recent HTC Google G1/Dream Cell Phone Black Rubber Feel White Diamond Protective C Questions & Answers
here is how you factory data reset your phone:
  1. Power off the G1
  2. Hold Home Key + End key for 20 seconds or until you see a "triangle with an exclamation point and a picture of the G1"
  3. Open the QWERTY keyboard and hit Alt+W
  4. Restored!
If you just need temp access and you can log into the google account associated with phone. Then you can: (With phone on) go to play.google.com from a pc. log in. and search for lock screen bypass. select your device and choose install. give it a few minutes to complete. reboot phone and wait for a bit and you will see the screen lock bypass app show up. click add admin account. sometimes it will throw you back to lock. just reboot and do it again. once you are at screen lock bypass app after adding admin account press BACK (pressing home will usually result in lock screen). And when you first boot phone its good to wait at least 2 - 3 minutes before pressing back to home screen. (I see better result and less lockscreen hiccups.) once you are finished you can reboot phone again and when bypass pops up you can uninstall from there. While in backup your dataicon1.png and do a factory data reset afterwords to get back into your phone properly. Good Luck
HTC Google... | Answered on Sep 12, 2016
try to reach somewhere near you an mobile technitions.
HTC Google... | Answered on Jun 04, 2014
You have to take it to where you have an account. There is no bypass. Once they verify it's your phone , they will reset it for you. That's to stop people from stealing someone's phone and bypassing the protection. Makes sense right?
HTC Google... | Answered on May 20, 2014
Ok, So I just had the same thing happen to me last night and I just fixed it. It'll take 2 people to do it. I went on to my gmail and changed my pattern, after a few minutes my phone had a triangle with an exclamation mark come up in the notifications bar. Don't bother turning off your phone...mine didn't reset for the pattern after 7 hours of being turned off. At this point, once you get that triangle, get someone to call your phone, it'll unlock it for a few minutes. Just long enough for you to change the password on your phone by clicking into that arrow. Then your phone will lock again after the call is done. Put the new password into your phone again on this screen. Then it'll ask you to draw another pattern. Draw something simplistic, then if you want to take it back off just go back into your settings and remove the lock....just remember your pattern this time! hope this helps!
HTC Google... | Answered on Apr 20, 2014
how can I unlock my screen pattern....I accidentally forgot it and doesnt accept my gmail account
HTC Google... | Answered on Mar 30, 2014
It's a data usage message. Going over your data. Or a failed download or message etc. Pull down notification bar by touching the top of the screen and pulling down. Should show up on the screen why there's a triangle.
HTC Google... | Answered on Mar 02, 2014
you need Nck or key network
you can get you Unlock code from
https://www.unlocklocks.com
HTC Google... | Answered on Feb 12, 2014
I have the same problem but once i restart the phone i get service back immediately
HTC Google... | Answered on Dec 16, 2013
reset then phone
HTC Google... | Answered on Nov 29, 2013
sir my mobile is htc dream and my imei number is 352779030269263
HTC Google... | Answered on Jul 04, 2013
Corrupted software
It isn't often that Apple gives specific directions about how to fix your problem! Restoring the iPhone 4 will erase everything on it, so make sure everything on the iPhone 4 is stored elsewhere prior to restoring. To restore, connect your iPhone 4 to a computer with iTunes installed. Click "Restore" on the iPhone 4 summary page (click on your iPhone icon on the left menu to find this page). Follow the directions to restore. If your iPhone 4 displays the text "Please wait. Very Low Battery," leave it plugged in. This charges the iPhone 4 enough to be able to restore. If the iPhone 4 hangs on this screen for long periods of time, you may need a new battery.
Force restore mode
If your iPhone 4 is hanging with an Apple logo, or exhibiting some other software problem that prevents iTunes from recognizing it, you can force it into recovery/restore mode and then use iTunes to restore the software.
If the device is powered off, plug one end of your USB cable into the iPhone 4 and leave the other end disconnected. Press down on the Home button, and keep holding it down while you plug the USB cable into your computer. After 5-10 seconds, you should see a "Please Connect to iTunes" image on the iPhone 4, and iTunes should prompt you to restore the software; follow the prompts and the instructions given above.
If the device is powered on, hold down both the power and home buttons until the device reboots and displays the "Connect to iTunes" image (generally, 5-15 seconds).
God bless you
HTC Google... | Answered on May 24, 2013
You must get the latest firmware installed. that should stop it getting hanged. And I hope you are not running additional programs in the background. If yes then stop some of them as they may be eating into your RAM and thus giving less breathing space to the phone to handle calls and the phone hangs.
Still You Have a Problem??????????
Mail Me At [email protected] I Will Guide You
HTC Google... | Answered on Sep 19, 2012
HI YOU need to contact your Service provider
HTC Google... | Answered on Apr 30, 2012
Hi, You need to provide your mobile's IMEI number, country and Network carrier details to unlock your mobile. It'll be helpful to find the availability of the service. Give those details and unlock your HTC G1 at TheUnlockArena.com . Here they provides you unique unlock code for your mobile with step-by-step instructions.. Hope it helps you..
HTC Google... | Answered on Apr 27, 2012
You can buy an unlock code on ebay for about $10-11 below is the link:
http://shop.ebay.com/i.html?_nkw=HTC+Google+G1+unlock+code&_sacat=0&_odkw=HTC+Google+G1%2FDream+unlock+code&_osacat=0&bkBtn=&_trksid=p3286.m270.l1313
www.usedcellphoneshop.com
HTC Google... | Answered on Feb 14, 2012
Hey friend i don`t know the code actully but i know the site from where i got my unlock code.the site have all unlock codes for htc phones you can easily find yours.click here to get your unlock code.
hope this helps..
You'll need to purchase an unlock code.
You will probably find a number of companies via google a I have used a couple, which I'm not sure I'm allowed to post here so I recommend you visit Unlock-Zone.com, which is nearly perfect and they were recommended highly in the cell phone forums.
Click the unlock your phone and select the mobile phone, current service provider to get the available unlocking service which ranges from $5 to about $25, depending on the model of phone you have.
HTC Google... | Answered on Nov 22, 2011
HTC Google G1/Dream Cell Phone Black Rubber Feel White Diamond Protective C Logo
104 questions posted
Top HTC Cell Phones Experts
Caltronic TV Repair
Caltronic TV Repair
Level 1 Expert
Marvin
Marvin
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
HTC Cell Phones
  • HTC Cell Phones
Most Popular Question
bypass screen unlock patern sony
  • Cell Phones
