20 Most Recent
Boatmates products are the final word in... Questions & Answers
Need to wire the starter solenoid on a 85
in my manual it says the yellow goes to the terminal marked S this is also the terminal that will get the motor going if you put a wire from the battery + to (the other one will do nothing, no damage or anything!) the orange (tan in the manual) goes to the R terminal. This gives full battery power to the coil when the starter is cranking.
9/19/2010 2:26:36 AM •
Boatmates...
Answered
on Sep 19, 2010
I have 30 hp two stroke pull start yamaha outboard
yam water pumps are clever the offste centre causes the pump vanes to flex during rotation and at low RPM you have a displacement type pump, at high RPM water pressure forces the vanes to flex inwards and the pump becomes centrifugal, you can fit the impellar either way up so you cant fit it wrongly make sure your gaskets are ok and that the delivery pipe to the power haed is not leaking (try a hose on it) also make sure the little woodruff key or on some models the pin through the drive shaft which turns the pump is fitted ok, not much else that can be wrong!
7/21/2010 9:35:00 AM •
Boatmates...
Answered
on Jul 21, 2010
4 beep alarm - Mercury 150 efi outboard
hi,
when the engine is running there is a repeated 4 beep alarm every 5 to 10 min. i have talked to several repair shops and they are unsure of the problem. what is the proper solution to fixing this alarm?
4/29/2010 2:50:24 PM •
Boatmates...
Answered
on Apr 29, 2010
I have a new ignition switch with sol, bat, and
You will need to use a voltmeter to test the wires. Ground one side of the voltmeter and check the wires with the other. One of the wires should give you the constant positive voltage. This wire should go to bat. Using the positive wire you found above check to see, by touchiung other wires to the 1st wire, which will give you ignition and which tries to "start" the engine. My educated gues would be that the purple will be your starter wire which will go to the sol, the orange will go to acc, and yellow with red will go to bat.
3/11/2010 3:07:23 PM •
Boatmates...
Answered
on Mar 11, 2010
Have green wire left on boat trailer all lights
It sounds to me that you may have it wired wrong. The green wire is typically the right turn signal. The basic colors-function are typically:
Yellow-Left turn/Stop, Green- Right turn/Stop, Brown-Running Lights, and White-Ground(earth)
1/28/2010 6:36:38 PM •
Boatmates...
Answered
on Jan 28, 2010
No running lights on a trailer
get a bulb and attach to wires run one to chassis to car and touch each output while someone switches on lights ot follow wire form output to the lights thay are connected to process of elimination, if car is "canbus" then proberly module
12/27/2009 10:25:22 PM •
Boatmates...
Answered
on Dec 27, 2009
What do you think about new york city exterminators?
There are various websites on internet that are presenting new york city exterminators. These are specially-made for those people that are trying to find quality service. To find out more please visit with this site :http://www.mypestsolutions.com/
4/18/2024 4:19:04 AM •
GPS
Answered
on Apr 18, 2024
My Conlog Prepaid electricity Meter is showing a spanner and not bring in light. What should I do?
Question edited for clarity. It is 'Conlog', not 'cinlog'.
It means there is a technical fault. Phone the company that supplies your electricity. It is their meter and distribution network.
What are the causes of a spanner appearing on ...
Quora
https://www.quora.com > What-are-the-causes-of-a-spa...
Jul 15, 2023 - A spanner icon anywhere indicates a need for maintenance. If the light is orange, get the service as soon as. If the light is red, call a ...
3 answers ยท 6 votes: Spaaner that appears on any equipment is the symbol of due for maintenance. Follow the OEM ...
Help! My Prepaid Meter Is Showing A Spanner Icon.
Nairaland
https://www.nairaland.com > prepaid-meter-showing-spa...
Mar 7, 2022 - I noticed my neighbours still had. On getting outside to check the conlog ip54 prepaid meter, I saw a spanner icon and a negative reading of the energy balance.
Please Help With My Conlog Prepaid Meter - Technology Market
Aug 6, 2020
I Need A Technician To Fix This... - Nairaland / General - Nigeria
Jul 22, 2019
Please Help With Conlog Prepaid Meter - Technology Market
Oct 9, 2022
Help My Prepaid Meter Stopped Displaying! - Nairaland Forum
Aug 3, 2023
More results from www.nairaland.com
3/8/2024 9:09:19 PM •
GPS
Answered
on Mar 08, 2024
