20 Most Recent Panasonic MC-V7355 Upright Vacuum Questions & Answers
check for a clog by removing the bag mini emptor (plastic bottom of the bag) twist it off by rotating it away from the vacuum
Panasonic... • Answered on Jan 03, 2010
it is probably a thermal issue. contact any local vacuum dealer.
Panasonic... • Answered on Jul 30, 2009
Do you mean the beater bar belt or the motor shaft belt? If so, you need to set the vacuum in a horizontal configuration and turn the vacuum upside down. Next remove the five screws from the base plate and lift the base plate off. To replace the motor shaft belt, remove it from the outer pulley and the motor shaft. Put the new belt on the motor shaft and the outer pulley. To replace the beater bar belt, release the motor shaft belt to allow access the beater bar. Lift up the beater bar assembly to remove the beater bar belt. Replace the beater bar belt. Replace the beater bar assembly. Replace the motor shaft belt. Turn the beater bar assembly by hand to check that the unit is seated correctly. Put the base plate back on the vacuum. Align the tabs on the base plate with the slots on the vacuum and replace the five screws. The manual for the Panasonic MC-UG304 is available here: https://www.manualslib.com/manual/940210/Panasonic-Mc-Ug302.html . See page 5 for images of the steps. I hope this helps. Cindy Wells
Panasonic... • Answered on Jul 11, 2019
I have a similar vacuum. You literally will have to flex/pry carefully to separate the plastic shroud (Horizontal part from the upright portion. Then you can remove the panel covering the motor, trace the cord to replace. Have done that several times. When you do, you might want to purchase the long industrial cord for future convenience.
Panasonic... • Answered on Feb 01, 2019
You should reset your machine when on short carpet It sounds like it's too low to the carpet making the suction too great. On long carpet you still have to raise it enough to get the right suction.' You have to get the right air flow to do a good job.
Panasonic... • Answered on Dec 15, 2018
Usually,you can just remove the bottom cover of the vacuum and replacing the wheel is fairly self-explanatory. Just remove the broken one and position the new and close the bottom cover. Hope that helps
Panasonic... • Answered on Jun 24, 2018
I'm not sure I understand what you are asking. The hose is not designed to pull the vac but if you pull and stretch the hose out and do something to restrict the airflow into the wand or hose it can pull the vacuum towards you or tip it over. It will only do this when the hose is stretched out because the suction is trying to pull the hose back to the vacuum but if it can't it will pull the vacuum towards the hose.
Panasonic... • Answered on Apr 23, 2018
Dirt Sensors are sensitive. It doesn't take much to set them off. Try pulling back on the handle to raise the brushroll a few inches off the floor so you know it's not detecting particles of soil. If the light doesn't turn green it may have dirt on the sensors and need to be cleaned.
Panasonic... • Answered on Nov 26, 2017
if the noise goes down when you cover the hole, the problem is that the vacuum hose or that side of the machine is blocked that is less load for the motor and so it goes faster blocking the hole prevents air out and so the motor slows down the same effect as if you put you hand over the hose , the motor speeds up
Panasonic... • Answered on Jan 06, 2017
You must remove the roller assembly to install the belt.
Panasonic... • Answered on Oct 17, 2016
The top part of the nozzle pops off just put small screw driver on side and lift up under the top lid is 2 screws then pop off by putting screw driver on sides to lift the housing off base plate here is roller Sears Kenmore Brush Roller 8192670 8175102 And 742454 and roller Sears Kenmore And Power Mate Canister Power Nozzle Belt Part 20 5285
Panasonic... • Answered on Jul 03, 2016
Most vacuums have plastic tabs and a plastic mechanism of some sort to that will engage those tabs to make it stay upright. I am suggesting either the tabs are worn down, or are broken off, or maybe the locking mechanism is broken. These parts are most often not replaceable, unless you can find an identical machine with these still good on it, and swap whatever parts are necessary to fix it. Machine is a "throwaway " model. When it breaks, you are expected to buy a new one. God bless your efforts.
Panasonic... • Answered on May 02, 2016
Panasonic MC-V7355 Upright Vacuum Logo
Popular Tags
4 questions posted
Top Panasonic Vacuums Experts
ENFORCER
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Panasonic Vacuums
  • Panasonic Vacuums
Most Popular Question
no suction in vacuum panasonic mc v7355
  • Vacuums
