20 Most Recent Dell Inspiron E1505, Intel Core 2 Duo T5300 , 15.4-in LCD, 1GB RAM, 120GB SATA HDD, 256MB Questions & Answers
Dear rdg5980,
Try to replace the battery (if it is a Laptop PC) or try to check the hinge or rainbow-cable that connect your Power to Monitor screen, it might be the socket little bit loosen.
GoodLuck!
Dell Inspiron... | Answered on Aug 28, 2009
the answer would be the same as.
I dropped my PC to the concrete, , how many pieces did not break.
same answer (only GOD knows that).....
the answer can be :
1: yes, if lucky, if the motor spins and can hear it , does it?
2: no if motor silent. Impossible unless pay $1000's bucks recovery services (google that. "clean room HDD recovery services")
3: yes and no, some files can be recovered,
ever seen a record player turn table,?
Imagine deep scratches, killing one song or 3, or?>
but the other tracks still play on the phonoGraph.
same deal here. but tracks are called cylinders here.
but if the heads are dead, NO,
first:
what you do is listen the drive , if the motor inside, is dead, it' s a dead HDD.(RIP)
if not, then move the HDD to other PC as second drive.
and copy your files, that way.
if possible it will work. (luck happens, fate, entropy ,etc)
Dell Computers &... | Answered Yesterday
What color(s) is (are) the blinking light? Is the blink a simple on/off or is there a pattern to the blinks (long/short)? Do any other lights come on and blink? (These could be on the keyboard or the battery health indicator LED.)
If the light that is blinking amber or orange indicates that the system has failed the Power On Self-Test (POST). If the blinking light is white, the system is in sleep mode. Try disconnecting the power adapter. Take out the battery and remove all external peripherals. Press and hold the power button for 20-30 seconds to discharge the system's capacitors. Try to restart the machine with only the battery and AC adapter. Did the behavior change?
You can remove memory and the hard drive to check if those are causing a POST failure. Reinstall one memory stick at a time if you have a pair or more. If you can get to the Dell splash screen, try pressing F12 to launch the diagnostics. (You may have to press the key repeatedly starting from a cold boot.)
If the blinking light is alternating orange and white, then you could have a problem with the motherboard, battery or AC charging system. Since you believe that the battery and adapter are OK, then the problem would likely be the motherboard has been damaged. The damage could be at the connection for the charger or somewhere else.
I hope this helps.
Dell Computers &... | Answered 3 days ago
To reset Windows 7 password with Spower Windows Password Reset, just follow the steps below:
Step 1: Download Spower Windows Password Reset Professional (trial version) and install it in an accessible windows. Spower Windows Password Reset Professional can be installed in windows 2000/xp/2003/vista/7/8/10/2008/2012/2016.
Step 2: Create a Windows password reset disk. You can use Spower Windows Password Reset to create a bootable CD/DVD or USB disk.
Step 3: Set the locked computer to boot from CD/DVD or USB drive.
Step 4: Boot the locked computer from Windows password reset disk.
Plug in Windows password reset disk to the locked computer, and restart it. Wait for a few seconds, Spower Windows Password reset program will start and ready for you.
Step 5: Reset forgotten Windows 7 password with Spower Windows password reset program.
When the Spower Windows password reset program is ready, do the steps below to reset windows 7 admin password:
Dell Computers &... | Answered on Jul 08, 2020
this is problem with overheating of motherboard. Please refer to the link. https://www.dell.com/community/Laptops-General-Read-Only/Error-code-M1004/td-p/3006198
Dell Computers &... | Answered on Jun 30, 2020
Start by pressing the menu button, select System, select Admin Menu, select Network, Select Wireless Setup, select your network from the list, then enter your network passphrase. Print a Settings Report to confirm the printer has successfully joined your wireless network.
Press Ctrl-P while booting up
Management Engine will open
use 'admin' as the password
you are required to set up a new p/w, do it.
It will prompt and say if you do it will reset, that's what is required!
then exit,
once it restarts, the error message disappears!! now you can install OS as usual
Dell Computers &... | Answered on Jun 28, 2020
Larry Ng is our computer guru. His advice is priceless and encyclopedic. His answer should be down here, so the answer is searchable.
Larry writes
What PC what DELL PC is this, must I guess?
Google dead today, hint 1 you are not the first nor last.
2000-0334 , it you failed to type the whole error
not even told laptop or desktop or just what model PC, (vast exist)
1000-0334 or this?
a video card GPU error of some kind
reload the Dell card driver from dell.com
or is the iGPU failing, in the CPU.
for same reason bad drivers.
if you installed W10 and dell.com told you not to do that , bingo, for no w10 drivers at dell for 10 year old PC or older, , NO PC told no OS told so there is no CLEAR answer,. ALL I can do is beg and pump,, endless
Dell Computers &... | Answered on Jun 20, 2020
You will get advice on how to format the hard drive and start again but there is no solution to lost passwords for security reasons.
You can use Kernel for Outlook PST Repair Tool to repair your damaged Outlook pst file successfully. Go to http://www.pstfix.com
to download the tool and refer to http://www.pst.msoutlookrepair.com
to know more about the pst recovery.
Dell Computers &... | Answered on Jun 18, 2020
You will need to go to customer care it will be great if your device still has warranty.
Dell Computers &... | Answered on Jun 12, 2020
Files that contain the .edb file extension are most commonly used by mailbox data files that have been saved by the Microsoft Exchange Server.
Dell Computers &... | Answered on Jun 03, 2020
1 is bios corruption or motherboard failure.
3 is motherboard or chipset error
2 is memory not detected
Dell Computers &... | Answered on Jun 01, 2020
do you already install audio driver on your laptop? if not.
here
just download this software,no need search engine,no more tired of looking anywhere...instantly,it will be in your laptop for several minutes....
CLICK ME
KEY : JCCQ-MAKC-KACK-6TSE-BN35
Driver Robot updates:
* Sound card drivers
* Printer drivers
* Video card drivers
* Motherboard drivers
* Webcam drivers
* Wireless drivers
* Bluetooth drivers
* FireWire drivers
* Ethernet drivers
* Windows XP drivers
* Windows Vista drivers
* USB drivers
* Chipset drivers
* AC97 drivers
* DVD drivers
* Router drivers
just install it,scan and download... enjoy...
Dell Computers &... | Answered on May 26, 2020
http://www.nsf.repair/
NSF Repair Kit is an end-to-end solution for the problem of corrupted Lotus Notes files of the NSF format. This Lotus Notes NSF repair tool uses a uniquely efficient proprietary file analysis core and a number of advanced algorithms to open files with any degree of damage and successfully extract their contents.
Dell Computers &... | Answered on May 05, 2020
PC came new with W10-64bit.
you meant just exactly after the upgrade it failed.
right, you meant the UPGRADE (from what?) failed hard.
that error means the boot files are corrupted.
easy if HDD bad. test it.
is the HDD good? did you use secure boot or legacy boot to do that,?
There are lots of possible cures. here.
one is to ask dell for help on there forum.
they can tell you how the original OS was set up.
and they also have your drivers.
no clues.
Dell Computers &... | Answered on May 04, 2020
Hi Tushar,
My name is Pradeep and I work for Dell's Social Media Team.
Please disconnect external devices and try running the application.
Please update video and chipset driver. The video card on the system might not support DirectX 11.2 which is included in Windows 8.1. Please download DirectX 11.1 using the link: https://support.microsoft.com/en-gb/kb/179113/en-us
Pradeep Lokesh
Social Media and Community Professional
Order Status: http://del.ly/61822hij
Download Drivers: http://del.ly/61832hid
Dell Computers &... | Answered on Apr 28, 2020
Dell Inspiron E1505, Intel Core 2 Duo T5300 , 15.4-in LCD, 1GB RAM, 120GB SATA HDD, 256MB Logo
1 questions posted
Lee Hodgson
Lee Hodgson
Ekse
efs_perpends
efs_perpends
View Most Popular
  • Dell Computers & Internet
Most Popular Question
montitor goes black or system shuts
  • Computers & Internet
