20 Most Recent Buck 2006 07 Bowman Chrome Bobby Simmons Milwaukee s Basketball Card #75 - M Questions & Answers
I want puk code for my phone number 015163040714
Buck 2006 07... | Answered on Sep 22, 2015
i need puk code for my lebara
Buck 2006 07... | Answered on Dec 13, 2012
These directions are for an AT and T phone, but other than that, are the same for any carrier. A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from your phone carrier to unlock your SIM card. You can obtain your phone's PUK code from your carrier in one of these ways: Log in to Your account.online Use a Technical Support Chat Contact your carriers Customer Care Get Your Phone's PUK Code Online Go to the Phone/Device page. From the My Phone/Device screen, select the Unblock SIM Card link under the My Make & Model heading. The Unblock SIM screen will display your PUK code and will give you instructions for unblocking your SIM Card. Once you receive your PUK code, you will need to enter it into your phone to set a new PIN code. Note: If you enter the wrong PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator
Buck 2006 07... | Answered on Oct 26, 2011
Hi, To get PUK code please contact your service provider.they will provide you the defaultPUK so that you can open your phone. While you get the PUK code ,the serviceprovider customer care officer will askfor your personal details to checkwhether the mobile belongs to you only.If they are satisfied with your answers they will providewith the PUK code Note: if you keep entering random/unknown numbers/codes, the sim card will be lockedand will be rejected. It'll not beusable anymore. If you need further help, let me know. Good Luck. Thanks for using FixYa.
Buck 2006 07... | Answered on Feb 26, 2011
Hello
Thank you for using Fixya!!
The PUK code requested is an unique code to each phone. At the link below you will be directed to a tip i wrote on how to recover your PUK code.
Click HERE to navigate.
Kind regards
Lock123
Buck 2006 07... | Answered on Feb 15, 2011
Do not enter any code into your phone. The PUK code is a code that your service provider has and not one that you would know or have in your manual. If your an AT&T customer they do provide PUK on their website. If you have entered in a code and the phone is now saying PUK blocked you'll have to go to store to purchase a new SIM card.
Buck 2006 07... | Answered on Apr 14, 2010
The first Egyptian pyramid was 204 feet or 62 meters high, built at the direction on Pharoah Djoser in around 2630 B.C. The tallest was the Great Pyramid at Giza, standing at an impressive 481 feet or 147 meters. The smallest was the Pyramid of Pepi II, which stood at a paltry 172 feet or 52 meters. Just based on Egyptian pyramids, the average height is about 316.5 feet or 96.375 meters. Considering the technology of the day, the pyramid builders were quite impressive to say the least. Hope this helped and best wishes.
Sport & Outdoor... | Answered Yesterday
The blue and yellow go on the left and right red goes in the middle the shortest blue and yellow go in the center loops
Sport & Outdoor... | Answered on Oct 18, 2020
I am looking for a manual for Greatland Outdoors 2 room tent with screen porch item #15710, however, I guessed how the poles go together. I set up the tent by myself, but I recommend 2 people or more, especially if it is windy.
Start by stretching out the bottom of the tent into a square, and stake all of the perimeter tentloops to the ground, starting with the corners, with the stakes directed at a 30 to 45 degree angle under the tent, so the tent cannot easily pull them back out. Leave the yellow cords attached to the tentloops loose, so you can use the cords to help pull up the stakes when you take down the tent.
Now assemble the poles going through the loops across the front of the screen porch. Insert one end of a pole #1 into a pole #2 and thread them through the loops over the entrance to the screen porch. Put the long end of a curved pole #3 through the loops starting from one side, and attach to either side of the 1/#2 you made. Put the long end of another #3 through the loops starting from the other side and attach to the loose end of the #1/#2. You should tie the loose green cords on each corner of the sceen porch to the silver metal rings at the curved end of each #3.
Later, you will do the exact same assembly with a #3 on each side of a #1/#2 for the poles going across the back of the tent and the poles going through the pocket across the middle/top of the tent.
Now insert the small end of pole #4 into the curved end of a #3, then insert the small end of a #5 into the open end of the #4. There should be a rubber foot on the bottom of the #5 pole. Do the same thing for the other side of the porch. With help, you should be able to prop up the front of the sceen porch, pulling aganst the stakes holding the rear floor of the tent, and place the rubber feet of the #5 poles close to the center loops of the floor on each side.
Now prepare the #1/#2 poles for the rear, and attach a #3 to each side and tie the loose green cords to the silver rings on the short ends of the #3s. Prepare a #4/#5 pole the same as the front, and prop up the back of the tent, putting the feet near the side loops of the floor which are about 1/3 from the rear of the tent.
Make another #1/#2/#3, and push it through the pocket across the middle of the tent, and connect the last #3 from the other side. The side supports for the middle are pole #8 with the white clamp on the bottom, and pole #7 slid into pole #8 (The #7 was scraped off both of mine). Leave the #7 mostly inserted into the #8 until after the center is lifted up. The #6 goes on top of #7, and insert the #6 into the curved end of the #3 poles which are already in the center pocket, and tie the loose green cords to the silver rings at the short end on each of the #3s. Now lift up the center with someone helping on the other side, and put the feet of the #8 into or near the yellow loops at the center of each side. Loosen the white clamps and extend the #7 poles until the peak of the tent is at proper height.
Move the feet of the #5 poles closer to the tent, until all is tight, and you should be done!
I have a manual for this model. I can not tell you how to find one, I have looked all over the net for additional info. on this model and can't find anything. Would be glad to scan and send you a copy if you still need it.
Sport & Outdoor... | Answered on Sep 15, 2020
If you need service or parts for the vital fitness RB260 bike call 888/337-2883 mon-fri 8 am-4:30pm (EST)
Sport & Outdoor... | Answered on Aug 18, 2020
https://www.answers.com/Q/Where_can_you_get_instructions_for_the_ten_peaks_tent_by_quest
Unfortunately, the web site given in the link above is no longer in service, so it may be difficult to find instructions other than those at the link.
Quoting from the link above: '
"Ten Peaks Tent by Quest
1) Lay out the tent flat on the ground, be sure to stretch floor to eliminate slack. Drive a stake into each corner loop, then drive the remaining stakes into the side loops.
2) Install the poles by first separating them by their color code. Yellow poles make up the center section. Red poles make up the right and left sides. Slide the yellow poles through the center pole sleeve. Slide the red roof poles through the right and left pole loops of the tent.
3) Raise the tent. Assemble the yellow upright poles and attach them to the yellow roof poles. Raise the center of the tent to its approximate height, by using the quick clamps on the bottom of the yellow center uprights. Assemble the red left and right support poles, attach the support poles to the roof poles. Place the side support poles on the ground near the side stake loops. Adjust the placement and the height of the poles until the tent stands firm.
Sport & Outdoor... | Answered on Aug 08, 2020
there are many types of grips in Disc Golf that are divided into 4 main categories:
Backhand Grips Forehand/Sidearm Grips Fan Grips for Putting & Approach shots Specialty Grips
To see all types of grips, check this out: http://www.innovadiscs.com/home/daves-tips/daves-grip-tips.html
Sport & Outdoor... | Answered on Jul 31, 2020
Buck 2006 07 Bowman Chrome Bobby Simmons Milwaukee s Basketball Card #75 - M Logo
14 questions posted
Top Buck Sport & Outdoor - Others Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Buck Sport and Outdoor - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Buck Sport & Outdoor - Others
Most Popular Question
need puk code lebara
  • Sport & Outdoor - Others
