20 Most Recent BigHorn 4 Bike Carrier Questions & Answers
if the spark plugs sink in oil so you need to change the rubber for the cam cover, if the oil come from inside the engine which is up-normal you must find it in water too, so you need to open the engine and see what is the problem.
BigHorn 4 Bike... | Answered on Jan 13, 2014
Sounds like your alternator is not charging. If you put a meter on the battery terminals while it's running it should be putting out between 12-15 vdc ( volts dc current). If not then more than likely the alternator is shot. You can take the battery to a parts store and alot of them will check it out for free to make sure you don't have a bed cell. If you're not getting the correct battery volts while running then I would replace the alternator.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_5bac37c3cb991fdb
BigHorn 4 Bike... | Answered on Nov 16, 2013
Yes, you should go for car wrap, it has many advantages like a high quality film will help you to prevent color fading, flying glass splinters during accidents and heat protection etc.
A nice Auto folie will enhance the appearance of your vehicle.
Vehicle Parts &... | Answered on Jun 09, 2020
you can purchase from:
https://www.amazon.com/Adapter-Charger
Vehicle Parts &... | Answered on May 29, 2020
https://help.compustar.com/s/article/How-Do-I-Exit-and-or-Enter-Valet-Mode
You can see this link.
Vehicle Parts &... | Answered on May 07, 2020
Suggest to do a patent search and review some diagrams. That will get you started.
Vehicle Parts &... | Answered on Feb 13, 2020
Google
year make model valet button
it is impossible for us to guess!
Vehicle Parts &... | Answered on Jan 12, 2020
on a car security, no idea, but on Android, this is how.
How to reset your Android screen lock security pattern ... TechRepublic Draw the pattern, click Continue, draw the pattern again, and you're back in business. You can also increase the security of your phone by setting it to lock ...
How to reset your Android screen lock security pattern TechRepublic
Vehicle Parts &... | Answered on Jan 06, 2020
When I hold the valet switch like am ask the led light lights up and stays on no chirping at all but if I hold the valet switch when the car is in the on position I get a chirp help someone please
Vehicle Parts &... | Answered on Dec 28, 2019
The supposed science behind polygraph tests is flawed, even proponents say it's only 90% accurate, (critics say it's far less at 70% or lower) so, at a minimum, for every 10 people that are tested 1 of them either gets accused of something they didn't do, or gets away with doing something. (or 3 out of 10 if you take a critic's side) And when it's done by Police, they are legally allowed to lie to you about your results!
Vehicle Parts &... | Answered on Dec 11, 2019
hi ,i need a pin code to nats...
vin :SJNBFAP11U0594153
NISSAN PRIMERA 2001 1.6
Please Help..
Vehicle Parts &... | Answered on Nov 30, 2019
same as jupiter all good
Vehicle Parts &... | Answered on Nov 08, 2019
Don't click on spammer Victoria Archer, as FIXYA doesn't remove most spammers automatically. Volunteers answer questions without charge.
https://www.scorpionauto.com/car-remote-alarm-immobiliser-scorpion-sa30/
Contact information.
https://www.scorpionauto.com/contact/
Vehicle Parts &... | Answered on Oct 25, 2019
Tip
Longer lasting engine maintenance
Your engine will last a lot longer as far as the main engine components if you 1)change your engine oil at vehicle recommended mfg intervals.TIP: if you live in hot climates you should change your oil more often and at less miles .2500 to 3000 ml. every 3 months because the climate the hot temperatures break down oil viscosity at a higher rate thus needed more frequent oil changes for the best engine engine lasting performance.2) always use the recommended weight example (5/30w)TIP: Also for best results the recommended rating of the oil for example on the back of the oil bottle is a rating 2 or 3 letters in a circle .Older vehicles use a different rating than newer vehicles and some times they are not interchangeable this information should be available at your local parts store.3)TIP;: Always use the recommended (brand) oil filter.With the way cars are now especially ones with overhead cams and chains ,aftermarket filters might not supply the same pressure aspects of the original oil filter, So as far to have less or more pressure than that is needed to maintain these components correctly with the correct pressure.
Thanks hope this helps
on Oct 22, 2019 | Vehicle Parts & Accessories
BigHorn 4 Bike Carrier Logo
5 questions posted
Top Yakima Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Yakima Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Yakima Vehicle Parts & Accessories
Most Popular Question
oil spark plugs
  • Vehicle Parts & Accessories
