20 Most Recent RTO AquaScape 4500 GPH Pump Questions & Answers
2answers
Where to buy a 20' power cord for Aquascape Pro 4500 pump?
Maybe try to just buy a 20' extension cord cut off the connecting end and hardwire into the unit.... ?
7/19/2014 1:10:01 AM • RTO AquaScape... • Answered on Jul 19, 2014
My Aquascape 4500 pump immediately trips the GFI
The seal has failed allowing water into the sealed motor unit and it is now shorted to ground...in other words the unit is shot and needs to be replaced.
John
4/7/2011 3:42:03 PM • RTO AquaScape... • Answered on Apr 07, 2011
Impeller shaft broke at impeller. moytor started
i have the wsame problem. A new pump will run me 550 I dont think I could replace the impeller shaft
11/13/2010 2:52:37 PM • RTO AquaScape... • Answered on Nov 13, 2010
0answers
Pump runs for about 3 to 5 minutes and then cuts
You have checked that sure thing, but if you have that pump on a shared circuit that thing draws more amps than normal appliances or is competing with another appliance and popping the circuit. Try isolating the pump and also make sure the circuit can handle the amp load the pump is giving off. Hope this is helpful.. Good Luck!
8/21/2010 1:09:45 AM • RTO AquaScape... • Answered on Aug 21, 2010
I have a AquaScape 4500 GPH Pump it has worked
Where the wire goes into the pump there is a o ring thatis probably leaking and any sort of water the motor might be getting is tripping the breaker. You probably have it plugged into a gfi and it sense very low amounts of water, and trips, You can determine by plugging it into a regular outlet and it should work. But definently fix the oring at the point of entry on the pump
4/17/2010 1:54:22 AM • RTO AquaScape... • Answered on Apr 17, 2010
Shuts off intermittantly
Does it come back on after resting/cooling down. If does peobably kick out on heat overload and is resetting itself. If impeller is free spinning with NO roughness or side play in bearing probably too much head pressure,pumping too far or too small pipe wich will cause excessive pressure making pump work to hard
4/11/2010 6:34:33 PM • RTO AquaScape... • Answered on Apr 11, 2010
Aquascape 4500 not working
Typical with these pumps, pumps I have rebuilt that have done the same thing what happens is the bearings get loos and cocks the armature that is why it won't spin. I did serious research on these pumps and came up with a rebuild kit some parts bought some I make. I did mine 2 years ago and still working like a champ and have done over 20 locally with no problems. If your pump is noisy or the impeller has fallen off (typical) due to water getting in the unit and causing the bearings to fail email me and I can rebuild your pump. The process is simple send me the pump I will look at it and see if it can be rebuilt at NO CHARGE if it can be rebuilt you will save over 60% of a new one. Don't spend $349 - $599 on a new one let me look at it for free if I can rebuild it great if not you will have to buy a new one. I am not a dealer for any pumps so you will not have to worry about me selling you a pump and if you want the old one back pay the shipping and it it all yours.
3/9/2010 4:49:01 PM • RTO AquaScape... • Answered on Mar 09, 2010
Aquascape 4500 pump trips breaker when plugged in
water getting into pump.Thats what is triping it.
8/1/2009 8:23:14 PM • RTO AquaScape... • Answered on Aug 01, 2009
Stops running after warms up
It's eithe your coil ha heat soak and needs replacing or your fuel circuit isn't venting properly and is creating a negative pressure
11/22/2013 10:43:17 AM • RTO Garden • Answered on Nov 22, 2013
0answers
0answers
I have a hrb216tda lawn mower that runs fine for 2 to 3 min. then stops like it is out of gas. i put on a new carb and does the same thing
Make sure your shut off valve is on positon not part way off,check for a screen plugged up in fuel tank or inline fuel filter, check for bad spark plug engine oil top up maybe saftety sensor when oil is low if you remove the fuel line from carb does gas flow straight out no problem?Joe
10/10/2012 4:17:13 AM • RTO Garden • Answered on Oct 10, 2012
RTO AquaScape 4500 GPH Pump Logo
Popular Tags
13 questions posted
Top RTO Garden Experts
Sean Wright
Sean Wright
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a RTO Garden Expert? Answer questions, earn points and help others
View Most Popular
RTO Garden
  • RTO Garden
Most Popular Question
aquascape 4500 pump immediately trips
  • Garden
