20 Most Recent Desa International Comfort Glow Infrared Vent-free Gas Space Heater Questions & Answers
It has a thermostat that should shut it down, locate and clean if you can, try again , if it still is doing that have the temp sensor replaced
Desa... | Answered on Jan 08, 2015
Gas valve appears to be failing.
Desa... | Answered on Jan 29, 2014
lack of actual heat transfer
Desa... | Answered on Dec 05, 2013
flame sensor or connections. next step the fenwal control
Desa... | Answered on Dec 14, 2012
your burners is cloged from solfer or resdue from gas get steal brush and clean out burners then see if it will fire up.
Desa... | Answered on Feb 15, 2011
I am looking manual or answers for Comfort Glow Portable Heat System Model PHS/D with serial # 3D006270186
Desa... | Answered on Oct 17, 2010
http://fmisupport.hcents.com/
This website has all of the manuals for Comfort Glow Heaters.
Desa... | Answered on Mar 04, 2010
You may have to bleed some more air out of the system.
Your ODS pilot may be clogged with dust or lint and needs to be blown out with air(less than 30 psi).
Your regulator or gas valve may be faulty.
Usually, all the modification needed is to change the gas orifice like you do when converting water heaters from one type to another.
Desa... | Answered on Feb 27, 2010
If your heater does not stay burning then you should check each of the internal components over to ensure that they are working properly. Look at your heater's manual to do this. Failing this, the best thing to do is to buy a new one as the cost of repairing one can cost loads of money. Good luck :)
http://www.ventless-gas-heaters.com
replace your thermal coupling it runs frowm the gas valve to the flame
Desa... | Answered on Feb 01, 2010
Should be 3/8 so you want to have a small 3/8 nipple and a 3/8 x 1/2 reducer.
Desa... | Answered on Dec 31, 2009
Desa International Comfort Glow Infrared Vent-free Gas Space Heater Logo
40 questions posted
Top Desa International Pool & Spa Experts
john h
David Spradling
David Spradling
rogerpaul3
Level 1 Expert
Are you a Desa International Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
  • Desa International Pool & Spa
Most Popular Question
pilot light
  • Pool & Spa
