20 Most Recent
AO Smith 2 hp Swimming Pool - Jet / Well Pump Motor / Century B124 Questions & Answers
I have a A.O Smith 2 HP motor. Is there any way I
Sorry, but no. Reversible AC motors are very different. Without that design difference (which adds cost) you can't reverse it. Your label is telling you that you don't have the special kind of motor.
My Jet Pump Looses it's prime at night.
I assume the pump is not running at night. If the pump is higher than the pool, and the inlet and outlet to the pool are both under water, then you have a small leak. This could be allowing the water to leak out of the line. Or, if the leak is higher than the pool surface it is allowing air to leak into the line, which allows the prime to run down into the pool.
If you found this useful, please vote.
Thanks.
The jets quit working when I prime and attach the vaccum hose
you could have a leak in the vac hose or a shaft seal on the pump, if there is a wet spot under your pump there is a good chance the shaft seal is BAD.... some pumps are so strong you can starve the PUMP for water, the trick is to set your valve more towards the main drain./ hope this helps.. i'm your local pool pump motor repair guy
The pool pump cuts out sometimes when it is
sounds like the motor is too small for the job.? has the motor been changed? if not -have the run capacitor checked by your local pool pump motor repair guy also the SF and HP must match the impeller size this number can be found on the front of the impeller and SF,HP can be found on the motor ID PLATE. gather all this info when you buy a motor or impeller .. very important ! . if you find you are stuck with you new motor the FIX is to get the impeller that is right for your motor
