20 Most Recent
AO Smith 1.5 hp Swimming Pool - Jet / Well Pump Motor - / Century B123 Questions & Answers
A O Smith 2green motor with timer wiring.
It is hard to say because each motor Mfg puts their own spin on the high low terminals.there is usually a wiring diagram on the outside of each motor explaining that and it is clearly not on yours.I would go to the motor Mfg website to get a wiring diagram for your particular brand.Rod @ US Parts Center
Im hooking my pool pump
There should be a diagram on the side of the motor showing you where to put the brown and white for 110/220 volt operation. Most new motors of this size are shipped strapped for 220v. The two hot wires will go to L1 and L2 and it doesn't matter which wire goes to which lug. For 220v you will usually have 2 black or 2 red wires and a green ground wire. If it is 110v supply, you will usually have a white and a black wire, and a green for ground. Hope this helps. Since you said you are hooking to 220v the brown and white should be on the correct lugs if this is a new motor.
I am installing a new pump and motor. the motor is
There is always a wiring diagram on the side of the motor. If you want help with this one still, you would have to list here the exact model of pump, and the model of the motor connected to it.
Most common connections are to run one hot line to L1 and one hot line to L2.
You would want to confirm this on the motor housing though as some motors are different than others.
