20 Most Recent
AO Smith 1 hp 3450rpm 56Y Frame 115/230 volts Square Flange Energy Efficient Pool Pu Questions & Answers
How can I run my aosmith 1hp pool motor on 115v?
LOOK ON THE MOTOR LABEL IT WILL HAVE A PICTURE ON HOW TO CHANGE IT, OR TAKE THE COVER OFF THE BACK AND LOOK CLOSE YOU WILL SEE HOW TO CHANGE IT..
jay the pool pump motor repair guy in longwood Florida 32750 .. BEST TO RUN PUMP ON HIGH VOLTAGE , IT WILL RUN COOLER AND LAST LONGER AND CHEAPER TO RUN $$$
How do I replace the
Remove the motor from the pump. Unscrew the 4 through bolts located at rear of motor. Tunr the 1/4" hex screw located at the front of the motor next to the shaft 1/4 turn counter clockwise.
Tap the front housing until it is removed (may need a bearing puller to remove it. Once this is removed, use a bearing puller to remove the bearing. Next, use 12" long piece or 3/4" metal electrical conduit to tap the new bearing into place making sure that the conduit is only coming in contact with the RACE of the bearing (the inner most track).
Reassemble.
Note: A molded bearing puller is needed fot this job. A formed puller will just bend/break.
It would cost less money to pay $75 to have this done by a proffesional rather than buying a $100-$200 tool just to try to do it yourself.
Ao smith century 1 hp
How do I change the front and back bearings in this pool pump motor 1hp. ao smith motot I did the shaft seal last year myself but needs bearings now. thank,Bill
If you have a 115
Usually - depends on the type of wire originally installed. Almost all of it is going to be rated 300V or more and if yours is then yes, change the breaker to a 2-pole and swap out any other devices in the circuit to be rated 230 and change the voltage selector on the pump motor to 230 and you are good to go. Examine the markings on your wire insulation to find the voltage ratings.
John
