20 Most Recent Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out, Center Discharge, 240V, w/Hair & Lint Pot Questions & Answers
Replacing a shaft seal requires some good mechanical ability.
first, always make sure power is off at the breaker before you work.
You'll have to remove the band holding the wet end to the seal plate. Then remove the diffuser covering the impeller. Remove the cover on the back of the motor. You either need a 7/16 open end wrench or a armature tool to hold the motor shaft while you unthread the impeller (if the impeller has a screw in the middle, you will have to remove it by turning clockwise, left hand threads) counterclockwise. You can then pull the carbon part of the seal off of the impeller, make sure to remove all of it including the metal sleeve. You will then have to remove the seal plate and push the ceramic part out from the back. You can then clean and lube the seal plate and install the new ceramic part of the seal, try not to touch the ceramic with your hands if possible. You can then lightly lube the impeller shaft and slide the carbon part of the seal with the carbon facing toward the ceramic as you thread it on. If the seal plate had a copper heat sink, you can either replace it or use a different size seal. (I believe it's a PS-201) Re-install the seal plate, impeller (and screw if applicable) and diffuser. You should now be ready to mate the seal plate to the wet end. Make sure you fill the pump before you try starting it up, especially with a new (dry) seal.
Sta Rite 1 HP... | Answered on Apr 12, 2015
what are you asking?
do you want to know how to plumb the individual pieces of equipment?
If so, skimmer port at the pool will go into the suction port of the pump, the port directly into the hair & lint pot.
discharge off the top of the pump will go into the Inlet of the filter valve, then the outlet of the filter will go to either a heater inlet port then outlet of the heater to the pool return inlet ports. If no heater, then from filter outlet directly to the pool return inlet fitting.
Good luck
Sta Rite 1 HP... | Answered on Mar 11, 2015
it sounds like you have a bad starting compositor. If your compositor is a black plastic one look next to the spade connectors in the cap and you'll see a little resest hole with a brown stopper in it. If that stopper is black, burnt or leaking oil it is bad. If you have a metal one you can set it on it's base on a flat surface. If it rocks it is bad. If the compositor is good you may have a problem with the windings and either need to replace the motor or have it rebuilt.
http://www.austinpooolspecialist.com/
Sta Rite 1 HP... | Answered on Feb 25, 2015
TRASH IN YOUR IMPELLER OR WORN PUMP, TAKE PUMP AND SPLIT IT LOOK TO SEE IF YOU HAVE TRASH IN YOUR IMPELLER AND LOOK AT OTHER PARTS FOR WEAR .. PRIME THE PUMP W/ WATER AFTER ANY PUMP REPAIR !!
.JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA.. REMEMBER TO VOTE FOR YOUR FAVORITE FIXYA GUY
Sta Rite 1 HP... | Answered on Aug 06, 2014
the front is the inlet the top is the oulet
Sta Rite 1 HP... | Answered on Jul 12, 2014
It could be several things but the most likely are: Something is spinning around with the motor shaft. Unplug the motor and "blast" water through the vent holes to clear debris. Let it dry completely before returning to service. Something could be caught in the impeller. Remove the front end and check. Squeals, loud hums, heat and vibration are indications of bad bearings.
Sta Rite 1 HP... | Answered on Apr 23, 2014
YES all pool pumps need to be primed, failure to do so will destroy the shaft seal AND could cause serious damage to the pump and motor. starving pumps is bad also. Make sure they have water, it makes them happy.
Sta Rite 1 HP... | Answered on Jun 06, 2013
could be a simple fix, take the motor down to your local pool pump motor repair shop that has free testing. it might be a bad thermal protector or a dirty start switch
always check for power first, could be bad breaker or bad or dirty timer contacts..jay
Sta Rite 1 HP... | Answered on May 30, 2013
Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out, Center Discharge, 240V, w/Hair & Lint Pot Logo
62 questions posted
Top Sta Rite Pool & Spa Experts
john h
Mike
David Spradling
David Spradling
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Sta Rite Pool & Spa
  • Sta Rite Pool & Spa
Most Popular Question
working but no water pressure
  • Pool & Spa
