20 Most Recent
Electric Jazzy Wheelchair 1170 Xlarge Plus Questions & Answers
We put the chair to
Mav your batteries need to be replaced. The voltage of the batteries is too low for the charger to pick up. Sorry but you should of removed the batteries from the chair while in storage or at least disconnected the cables. If Medicare paid for the chair then they may pay for reair if the batteries are under 6 months old then they should be under warranty contact your provider that sold you the chair Hope this helps
Why do the first two red diodes flash and beeps but will not move on my Quantum 610 electric wheelchair
<div><br>The first two red diodes flashing accompanied by beeping on your Quantum 610 electric wheelchair generally indicates a fault condition or an error code. Here are some possible reasons: Joystick Calibration Error: The joystick may need to be recalibrated. Check your wheelchair's user manual for instructions on how to calibrate the joystick properly. Error Code Identification: The flashing lights and beeping may be an error code. Consult your wheelchair's user manual to interpret the specific error code, as different combinations of lights and beeps can indicate different issues. Battery Issues: Low battery voltage or a battery fault can sometimes trigger error codes. Ensure that the wheelchair's batteries are fully charged and in good condition. Motor or Drive System Issues: Problems with the wheelchair's motors or drive system may prevent it from moving. Check for any loose or disconnected wires in the motor connections. Obstructions: Ensure that there are no obstructions or obstacles preventing the wheelchair from moving. Check the wheels and drive system for any debris. Controller or Joystick Malfunction: A malfunctioning controller or joystick can cause issues. If possible, try using a backup controller or joystick to see if the problem persists. Reset the System: Turn off the wheelchair, wait for a few seconds, and then turn it back on. This may help reset the control system. Technical Support: Contact the manufacturer's technical support or customer service for assistance. They may be able to guide you through additional troubleshooting steps or advise on the next course of action. Professional Inspection: If the issue persists and you are unable to resolve it through basic troubleshooting, consider seeking assistance from a certified technician who specializes in mobility devices. Always refer to your wheelchair's user manual for specific information on error codes and troubleshooting. If you don't have the manual, you can often find it on the manufacturer's website or by contacting their customer support. <br></div>
E2 error on electric scooter
Remove the battery cover and check (very carefully or you may cause a fire that cannot be extinguished due to the battery chemicals)! for bad connections between the controler and the scooter.
If all are good, take it for service at a service shop.
Hi I have a Dynamic DL 4.2i electric wheelchair, when it is turned on the leds just flash and chair won't move .
If your Dynamic DL 4.2i electric wheelchair is experiencing issues where the LEDs are flashing and the chair won't move despite fully charged batteries, there could be several potential reasons for the problem. Here are some troubleshooting steps you can take:
- Check for Error Codes:
- Electric wheelchairs often have a diagnostic system that uses flashing LEDs to indicate specific error codes. Refer to the user manual for your wheelchair to interpret these codes. They can provide valuable information about the nature of the issue.
- Inspect Connections:
- Ensure that all the electrical connections, including those between the controller, motors, and batteries, are secure and free from corrosion. Loose or damaged connections can disrupt the functioning of the wheelchair.
- Reset the Controller:
- Some wheelchairs have a reset button on the controller. Try resetting the controller by turning off the power, waiting for a few seconds, and then turning it back on.
- Check Joystick Operation:
- Verify that the joystick is functioning correctly. Sometimes, issues with the joystick or its wiring can affect the chair's performance.
- Test Batteries:
- Even though you mentioned that the batteries are fully charged, it's worth checking their voltage and overall health. Faulty batteries can still show a full charge but may not provide sufficient power.
- Controller or Motor Issues:
- If the problem persists, there could be an issue with the controller or the wheelchair's motors. In such cases, it's recommended to contact the manufacturer's customer support or a qualified technician for further diagnosis and assistance.
- Professional Inspection:
- If the wheelchair is still under warranty, consider contacting the manufacturer's customer support for assistance. If not, seeking the help of a professional technician with experience in electric wheelchair repairs may be necessary.
Always prioritize safety when troubleshooting or attempting to fix issues with electric wheelchairs. If you are unsure or uncomfortable performing the troubleshooting steps yourself, it's best to seek professional assistance to ensure the wheelchair is properly diagnosed and repaired.
How to hookup a 12v led to a 36v system on a electric scooter for a taillight.
To hook up a 12V LED taillight to a 36V electric scooter, you will need to use a voltage regulator to bring the voltage down to 12V. Here's how you can do it:
- Get a voltage regulator that can handle the voltage and current of your electric scooter. You can find voltage regulators at electronics stores or online.
- Connect the positive (+) wire of the taillight to the input of the voltage regulator.
- Connect the negative (-) wire of the taillight to the ground (GND) of the electric scooter.
- Connect the input of the voltage regulator to the 36V power source of the electric scooter. This may involve cutting and splicing wires, so be sure to use proper wire connectors and electrical tape.
- Connect the output of the voltage regulator to the positive (+) wire of the taillight.
- Finally, test the taillight to make sure it's working properly.
Keep in mind that the voltage regulator may generate some heat, so make sure it's properly installed and secured in a safe location away from any flammable materials.
My electric breaker blew when turned on bed and nowBottom of tanning bed, half bulbs won't come on
It sounds like there may be an issue with the wiring in your tanning bed. If a circuit breaker blew when you turned on the bed, this could indicate that there is a problem with the electrical system. This could be due to a short circuit or some other issue that is causing a high current draw. I recommend that you have a qualified electrician inspect the wiring in your tanning bed to determine the cause of the problem and make any necessary repairs. It is important to have this issue addressed, as it could pose a safety hazard if not resolved.
