20 Most Recent Pride Mobility Products New Pride Mobility Go Go Ultra X 3 Wheel Travel Scooter Questions & Answers
I would say to change the pot,its the variable contacts on the high end of the speed pot that is worn out not making contact.
Pride Mobility... | Answered on Apr 18, 2013
May I get the make and model # to help you more
Pride Mobility... | Answered on Aug 16, 2010
From a pure physics standpoint...
The energy to climb a hill... be it from the steep side or the gentle sloping side is the same...
It is just easier on your heart and joints to take the gentle slope... (assuming you have the time).
ERGO:
If treating the scooter like a QUEEN
is your goal... DEFINITELY GO SLOW.
Tat way you will have no idea if it has any weak spots when you need it to go fast (and you will).
I'm old... I don't have TIME to waste!
Carnac the Magnificent
Pride Mobility... | Answered on Mar 28, 2017
hi,
Sounds to me like the worm drive is slipping , this can happen when the worm drive small bearing is worn,
If you do take it a part , please take great care, the shaft from the motor will have a worm drive, two bearings on the worm drive,
Try to move the shaft within the bearings, I paid £10 for replacement bearings.
Please give me a update.
Regards
GeWiz.
Pride Mobility... | Answered on Sep 03, 2016
Maybe too late for this advice but it is important to take a detailed photograph of the wireing before unplugging anything.
Pride Mobility... | Answered on Jul 02, 2016
I'd recommend a dental pick.
Pride Mobility... | Answered on Jun 01, 2016
Hi not much info is there a red LED & green LED on charger...or is there a red LED & orange led on ?? Bit more info would help cheers
Pride Mobility... | Answered on May 16, 2016
Hi check the main circuit breaker c photo push the white button in to c if it has tripped open cheers
Yes a technician with a programmer can set the control very slow so it is limited on how fast it can go. Otherwise the joystick is meant to be adjustable, so setting it to one speed only not possible.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Pride Mobility... | Answered on May 15, 2016
hi Linda, can you please tell me what model pride this is ?
Regards
Rob
Pride Mobility... | Answered on Dec 05, 2015
Candy Apple paint is extremely hard to patch repair. It has a base coat of silver or gold and then multi coats of the candy apple over the top.
You can get a paint that is meant to be a touch up for candy apple but you never end up with the same shade of color. Most of the time it will come out dark blood red anywhere that it over laps the old paint.
I would contact Pride as they may use a paint that does not require a base coat.
Pride Mobility... | Answered on Oct 27, 2015
Check you're freewheel lever if its in freewheel u have to take the key out engage lever & put key back in. Also if u have left the key on for more than twenty minutes the circuit will shut down only the light will work. take key out for 5 minutes then put it back it should work unless it's another problem good luck
Pride Mobility... | Answered on Aug 03, 2015
Pride Mobility Products New Pride Mobility Go Go Ultra X 3 Wheel Travel Scooter Logo
4 questions posted
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Pride Mobility Products Health & Beauty
Most Popular Question
pride victory
  • Health & Beauty
