20 Most Recent RTO Cummins Onan HomeSite Power 5500 Questions & Answers
A free wiring schematic for onan 6.5 kw generator
What model is it
3/1/2015 11:52:55 PM • RTO Cummins Onan... • Answered on Mar 01, 2015
Onan Generator
id say its your idle jet is blocked. remove and clean carburetor thoroughly is solution or for quick fix try removing air filter and spraying carburetor cleaner into throat of carby whilst revving engine, repeat several times and perhaps that will flush it without need of removing carby.
5/14/2014 10:58:37 AM • RTO Cummins Onan... • Answered on May 14, 2014
I have an onan marquis 5500 watt RV generator that
Call Onan and tell them the Inverter Board is bad. If you're not producing AC Power, have them send you a new board or warranty the entire genset. It's unusual for Onan products to go out like that, but not unlikely that this is the source of the problem. Typically, the DC motor outputs at 12 volts, so the leads going in to the inverter are only going to be a ground and a positive lead. Should be very simple to replace. Worst case scenario is you can hook an external inverter up to the DC leads on the front of that generator. Might not get the full 5.5kw from the system, but you'll be able to produce some power.
10/18/2013 8:02:22 PM • RTO Cummins Onan... • Answered on Oct 18, 2013
My onan generator will not start and I have not spark
For more you can see in here wiki pedia.
8/11/2012 4:07:29 PM • RTO Cummins Onan... • Answered on Aug 11, 2012
I need an onan generater wiring diagram
Many times these generators are sold at camper/ motor home dealers some already installed in their units. It's an outside chance but they may have access to a manual. Also if generator has 1-800# call it.they may can help as well. Hope this helped God Bless
9/18/2009 2:34:28 AM • RTO Cummins Onan... • Answered on Sep 18, 2009
Why is one contact of a 12V DC circuit breaker
Hello
Reason for this is,the copper side carrys the voltage or hot side.
the other side would be a ground or neutral.
Copper is the best conductor of electric power.
1/4/2012 8:03:15 AM • RTO Electrical... • Answered on Jan 04, 2012
Manual for scorpion sl2800 generator
Yes
4/9/2024 2:32:16 AM • Electrical... • Answered on Apr 09, 2024
2answers
My conlog meter is showing the rfcon error please what do I do
No connecting to your utilty company in South Africa. Just FYI, we are a North American site and my not always have the answer, in this case we do Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error-cant-do-anything-on-the-gadget-please-help-on-how-to-re/962048393965724/ Quoting from link above: "Conlog Hi Ola-daniels, Please see below steps to assist with RFCON error : * Press the Back arrow on the keypad - this step is to refresh the UIU ( the device) * Type # 75 # - this is to check the signal strength If it does not go back to the normal display *Type # 80 # - this is to refresh the meter Then lastly you can repair the meter and the UIU by # 36 # The above steps will work better if you are outside the house because the meters uses the radio frequency connection The above error will occur in instances of bad weather conditions or if there is load shedding or power failure If the problem persists after trying the above you may contact the municipality or the service provider."
SOLVED: How do I clear up the rf con error on my meter ...
https://www.fixya.com > ... > The
May 7, 2020 - How do I clear up the rf con error on my meter because I want to ... Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error- ... Hi Ola-daniels, Please see below steps to assist with RFCON error : ... shut down the energy alimentation for 2 minute ,but if the defect persist error it show again. SOLVED: Pole meter conlog rf con meter keep on freezing ... Jan. 10, 2017 Meter reading shows rF CON instead of units available - Fixya Jun. 24, 2018 SOLVED: Good day my conlog ip54 elecricity meter showd ... Oct. 6, 2018 SOLVED: Rf con error - Fixya Jun. 20, 2020 More results from www.fixya.com
Please Help With My Conlog Prepaid Meter - Technology ...
https://www.nairaland.com > please-conlog-prepaid-meter
Aug. 6, 2020 - ystar: If the conlog meter is showing rf-Con, it means power supply doesn't reach the meter at all its either Loss of phase from the transformer or a loose contact ... How Do I Load The Activation Token On My Conlog Prepaid ... Mar. 17, 2020 I Need A Technician To Fix This... - Nairaland / General - Nigeria Jul. 22, 2019 I Need Number Codes To Reset Memmcol Prepaid Meter ... Jan. 11, 2019 More results from www.nairaland.com
3/24/2024 3:42:46 AM • Electrical... • Answered on Mar 24, 2024
Wiring 3 lights 3 separate switches
Consult a qualified electrician.
3/23/2024 7:13:23 AM • Electrical... • Answered on Mar 23, 2024
Kawasaki GA1400A Generator. It starts fine, 12 volts okay, but no 230 volts.
Question edited for clarity. Question moved from Motorcycles to Generators category. Some help in the link, but not as much as I would like https://www.google.com/search?q=Kawasaki+GA1400A+no+230+volts+output ..
2/11/2024 5:52:06 AM • Electrical... • Answered on Feb 11, 2024
GE outdoor 200A fusible disconnect can not stay on position, how to fix this issue
It has a cantilever snap action. Either the spring has detached, broken, disabled or unit is otherwise damaged. Heat, water, rodent, etc damage. Replacing the unit is most likely your only option.
2/9/2024 12:37:45 PM • Electrical... • Answered on Feb 09, 2024
What are the valve specs for a kubota av3800 generator
I want PDF AV 3800 Generator
2/8/2024 2:59:27 AM • Electrical... • Answered on Feb 08, 2024
RTO Cummins Onan HomeSite Power 5500 Logo
13 questions posted
Top RTO Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you a RTO Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • RTO Electrical Supplies
Most Popular Question
onan marquis 5500 watt rv generator
  • Electrical Supplies
