20 Most Recent Black & Decker 750w Power Inverter Questions & Answers
http://servicenet.blackanddecker.com/Parts/Search?searchedNumber=750%20Watt%20Power%20Inverter
There are around 8 models of the 750 watt inverter. The above web link takes you to the Black and Decker site where you can input your exact model number and then you can download the instruction manual which has the details for how to change the fuse.
Black & Decker... | Answered on Mar 01, 2015
Hi, you need to remove the cover of the unit and inspect the three 40 amp fuses inside. They are the blade type similar to the ones found in automobiles. Hope this helps
Black & Decker... | Answered on Nov 17, 2010
I think the needle nose pliers may be best. insted of grabbing by the thin sides, grab it the wide way and gently rock it back and forth. I think this is like a 35 amp fuse, so the holder has to be very tight to keep a good connection. I have one of these, and for two days I thought it was bad untill I pressed the red on button.
Black & Decker... | Answered on Jul 26, 2010
Inverter is charging battery but if I switch on load button , It starts making noise loudly. can you suggest solution
Black & Decker... | Answered on Jul 01, 2010
look for a cover to maybe flip up or slide (most inverters fuses are coverd)
Black & Decker... | Answered on Jul 05, 2009
The answer is yes...BUT make sure the polarity is correct and the inverter turned off when you make the connection
Black & Decker... | Answered on May 07, 2009
I can't answer your question but I strongly suggest you urgently contact the manufacturer or dealer in order to clarify this most important point as a 3kw inverter isn't cheap and shouldn't need replacing very often.
Black & Decker... | Answered on Aug 31, 2017
Sure, you can find it on amazon... here: Amazon com Husky jump start adapter . I hope I have helped. Cheers
Black & Decker... | Answered on Dec 01, 2014
well the yellow light indicates a fault, the 5 volt USB is independent of the invert-er function, you kneed your unit serviced or possibly you have a low voltage cutout or high voltage protect ,check you manual for led fault indicator descriptions, battery voltages should be between 10.9 volts and 13.8 volts this can cause a fault if outside this range.
best regards Falco
Black & Decker... | Answered on Nov 05, 2013
Most power inverters supply a modified sine wave output. This is different from the true sine wave you get at home. It's close enough for many applications, but not close enough for many transformers, which is what your laptop power supply is. So the problem is that your laptop's power supply does not work with a modified sine wave input. Some will, some won't. Very common problem.
Black & Decker... | Answered on Aug 23, 2010
Black & Decker 750w Power Inverter Logo
13 questions posted
Top Black & Decker Electronics - Others Experts
Sheldon Dedek
Vernon Taylor
Are you a Black & Decker Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Black & Decker Electronics - Others
Most Popular Question
reversed cables blew fuse get out
  • Electronics - Others
