20 Most Recent Kwikset 907 907-L03 Lifetime Polished Brass Smart Code Smart Code Deadbolt Questions & Answers
Here is the instructions from kwiksets website
http://www.kwikset.com/Files/PDF/SmartSeries/SmartKeyInsEnglishOnly.pdf
Kwikset 907 ... | Answered on Nov 01, 2010
It sounds like the lock master reset might have been inadvertantly pushed when the coverplate was removed at some point. I would suggest you remove the batteries, reinstall them and reset the lockset and enter in new pass codes (you can use the same ones as before, if you wish).
I've attached the owner's manual, just in case you've misplaced yours, so you can reprogram the lockset and have the instructions for future use and reference.
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Just so you know, Weiser and Kwikset were once the same company and offerred the same lock under both names, so don't worry about the manual having the Weiser brand name on it.
Hope you find this Very Helpful - Best regards!
Kwikset 907 ... | Answered on Aug 19, 2009
Presumably the lock is defective.
Kwikset Locks &... | Answered on Sep 26, 2019
I don't know if this is the best answer, but I would try to slip a heavy credit card between the door and the jam where the knob is. It may be a quick solution for the moment.
Kwikset Locks &... | Answered on Jun 25, 2019
Have you released the knobs? They are held on with a small depression thing on the stem of the handle. Press this in and pull on the knob to release it.
Try the video it may be of some help but do the opposite
to the fitting.
Kwikset Locks &... | Answered on Jun 13, 2019
notify manufacturer or locksmith
Kwikset Locks &... | Answered on May 02, 2019
Remove it and take it to a locksmith or
go get a new one or
hire a locksmith to come out to your house
they have tools to be able to reset when you have no working keys
Kwikset Locks &... | Answered on Mar 23, 2019
It could be that you are trying to add a code again as well. You can not have the same code in say space one that you have in space 5.
My Kwikset lock has been working beautifully for several years now, and it is handy to not have to use keys.
If you can't figure out the programming, and want to start from scratch, with mine I believe that you remove the battery pack, press in on the program button for ten seconds, and reinsert the battery pack while still holding the program button. That erases all of the stored codes, and you can start over again.
None of what you described sounds like a locking issue, but a programming issue.
Kwikset Locks &... | Answered on Mar 07, 2019
Remove it, lubricate it and put it back. I have the same unit and they are reliable. If yours is a bad fit into the door, that is your problem and the tenants have forced it. The bolt should slide in easily into the mortise. The weather is changing, so the door has moved a bit.
Ideally, you should have a Schlage Knobset as well as the locking deadbolt. The deadbolt is not for locking the door, it is a failsafe for when you are out or at night asleep. The same key opens both. The knobset has a spring loaded catch and a knob on both sides. The inside one has a turn button to lock or leave knob unlocked.
Kwikset Locks &... | Answered on Nov 16, 2018
Kwikset 907  907-L03 Lifetime Polished Brass Smart Code Smart Code Deadbolt Logo
2 questions posted
Top Kwikset Locks & Locksmithing Experts
Charles Tidwell
ray gallant
STEVE SPAM REMOVER
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
View Most Popular
  • Kwikset Locks & Locksmithing
Most Popular Question
kwikset smart key no key need rekey
  • Locks & Locksmithing
