20 Most Recent
Schlage BE365-CAM BE365CAM619 Satin Nickel Electronic Security Camelot Elec Questions & Answers
Need to reset codes and need instructions, were
"How can I program my electronic keypad lock when the instructions with the Programming Code have been lost?"The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.Complete installation & programming instructions can be found here:http://consumer.schlage.com/Project%20Documents/P515-858.pdfNotice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:http://get.adobe.com/reader/Videos for installing and programming can be found on this page:http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspxScroll down and find them under the heading Electronic Security--Keypad deadbolt 365Good luck--and please provide feedback if this helps!
11/10/2011 2:57:58 AM •
Schlage...
Answered
on Nov 10, 2011
My schlage lock isn't responding. the battery has
11/8/2011 6:37:17 PM •
Schlage...
Answered
on Nov 08, 2011
I need to programming instructions for this lock.
BE-365 installation & programming PDF: http://consumer.schlage.com/Project%20Documents/P515-858.pdfHow can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.This number is the programming code referenced in the information for changing the entry code.Complete installation & programming instructions can be found here:http://consumer.schlage.com/Project%20Documents/P515-858.pdfNotice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:http://get.adobe.com/reader/Videos for installing and programming can be found on this page:http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspxScroll down and find them under the heading Electronic Security--Keypad deadbolt 365Good luck--and please provide feedback if this helps!
11/8/2011 6:27:35 PM •
Schlage...
Answered
on Nov 08, 2011
I press the schlage button
The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the dial. When disabled, you have to enter the user code, then turn the dial.To enable/disable this feature, enter your Programming Code--press the Schlage button--Press 7.Each time you do this, you toggle between enabled and disabled.Complete installation & programming instructions can be found here:http://consumer.schlage.com/Project%20Documents/P515-858.pdfNotice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:http://get.adobe.com/reader/Videos for installing and programming can be found on this page:http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspxScroll down and find them under the heading Electronic Security... 365Good luck--and please provide feedback if this helps!
11/8/2011 6:20:36 PM •
Schlage...
Answered
on Nov 08, 2011
After installing my lock, i don't have to enter my
The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the "dial". When disabled, you have to enter the user code, then turn the dial. So either way, you still have to turn the dial.To enable/disable this feature, enter your Programming Code --press Schlage button--press 7Each time you do this, you toggle between enabled and disabled.This link will take you to the page for programming information:http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspxThen scroll down to this heading on that page:Electronic Security-Keypad Deadbolt 365There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! Batteries should be replace about every three years.The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that programming code that you found on the backside of the keypad.A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:http://get.adobe.com/reader/Good luck--and please provide feedback if this helps!
11/8/2011 5:46:49 PM •
Schlage...
Answered
on Nov 08, 2011
Lock is 3 years old. Started flashing red and
This link will take you to the page that you need to get started:http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspxThen scroll down to this heading on that page:Electronic Security-Keypad Deadbolt 365There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! Batteries should be replace about every three years.The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that programming code that you found on the backside of the keypad.A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:http://get.adobe.com/reader/If you continue to have problems, contact their Customer Support.Good luck--and please provide feedback if this helps!
11/8/2011 5:20:19 PM •
Schlage...
Answered
on Nov 08, 2011
Keypad will not even light up - battery might be
This link will take you to the page that you need to get started:http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspxThen scroll down to this heading on that page:Electronic Security-Keypad Deadbolt 365There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! Batteries should be replace about every three years.The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that programming code that you found on the backside of the keypad.A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:http://get.adobe.com/reader/Good luck--and please provide feedback if this helps!
11/8/2011 5:05:40 PM •
Schlage...
Answered
on Nov 08, 2011
Need to delete all previous user codes. I have
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.This number is the programming code referenced in the information for changing the entry code.This link will take you to the page that you need to get started:http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspxThen scroll down to this heading on that page:Electronic Security-Keypad Deadbolt 365There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! Batteries should be replace about every three years.The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that programming code that you found on the backside of the keypad.A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:http://get.adobe.com/reader/Good luck--and please provide feedback if this helps!
11/6/2011 10:32:49 PM •
Schlage...
Answered
on Nov 06, 2011
I can push any button & the lock will open
BE-365 installation & programming PDF: http://consumer.schlage.com/Project%20Documents/P515-858.pdfA note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:http://get.adobe.com/reader/good luck.
11/6/2011 9:23:14 PM •
Schlage...
Answered
on Nov 06, 2011
It keeps flashing red when
First, change the battery. Complete installation instructions here:http://consumer.schlage.com/Project%20Documents/P515-858.pdf
11/6/2011 8:51:14 PM •
Schlage...
Answered
on Nov 06, 2011
How do I change the combination?
This link will give you instructions for various models of Schlage locks:
There is a video on this page, showing how to change codes.
3/6/2011 12:31:36 AM •
Schlage...
Answered
on Mar 06, 2011
How do i change my
3/6/2011 12:02:34 AM •
Schlage...
Answered
on Mar 06, 2011
Need to chanfe code
3/5/2011 11:54:53 PM •
Schlage...
Answered
on Mar 05, 2011
Once I lock the door and the lock disengages. In
It sounds like its a defect in the mechinasm of the lock Did it ever work and before and how old is it I can tell you this SCHLAGE is a vary low grade look as compared to say a baldwin look set it cost 60% less and is mass produced So not knowing the age and knowing the quailty level i would say its not worth it to try to fix this If you have a warrenty thats still valid for it mabey but it will end up costing more then the thing is worth to repair if it can even be done sorry im just telling the truth good luck
11/24/2010 10:42:23 PM •
Schlage...
Answered
on Nov 24, 2010
