20 Most Recent Electric General Ted134050 50a 480v Circuit Breaker Questions & Answers
1) If busbar looks good it probably is good.
Usually when bus is bad, it has burned appearance, and looks like it is ready to crumble or is crumbling.
2) Problem with bad busbar, we sometimes add subpanel next to main box.
Buy subpanel box Home center or electric supply.
Square-D subpanel shown on following page came from electric supply.
http://waterheatertimer.org/How-to-install-a-subpanel.html
3) You can also add tandem breaker to main box.
Tandem breaker fits over one bus finger, but is actually two separate breakers.
Then double-up two lightly used circuits so you have room to move breakers around.
See image showing tandem.
http://waterheatertimer.org/images/ap-235-breakers.jpg
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Electric General... | Answered on Feb 17, 2011
I would get an amp metetr on it and see what the load is.... if it is running continually at over 40 amp. then you are overloading it...and need to shed some load...
If it is not then the breaker is going bad and needs to be replaced...
heatman101
Electric General... | Answered on Nov 16, 2010
When you say breaker, presumably you refer to an RCD?
The residual current device will trip if the amount of current in the hot wire does not equal the amount of current in the neutral or return wire. This means some current is leaking away which means the chainsaws might have developed a potentially dangerous fault or might just be the result of an excess of damp sawdust entering the motor housing through the vents - or damp has entered the tools by other means.
I find a compressed airline useful for keeping power tools internally clean and dry.
Electric... | Answered on Feb 10, 2020
You need to use rated breaker and did you find a fault for why the breaker shorted?
Electric... | Answered on Dec 21, 2019
In the electric windows of - what - ?
Electric... | Answered on Nov 28, 2019
It cannot be connected to 120 volt ... this is a 12 volt photoeye that integrates into the screw terminals on power pack.
Following link has some basic information for connecting the photoeye
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#troubleshoot
Electric... | Answered on Oct 28, 2019
Connecting 12 batteries in series would give slightly more than 61 volts. Considering that under load voltage will drop then it should be ok. Breaker goes between battery and motor on positive wire.
Electric... | Answered on Oct 14, 2019
Hi!
We help people repair their Clarke Generators. You can find testing procedures here: https://www.generatorguru.com/contact-us/
We also hold all the parts possible for all the Clarke Generators and have a "Parts Search Service" if the part is not listed on our site. Check us out on our site.
Parts Spares for Generators and Small Engine Machinery
Electric... | Answered on Sep 13, 2019
either short or failure of gfci
Electric... | Answered on Jun 08, 2019
Tip
Repair broken power cord
I have a 50-ft power cord for my electric pole saw. In an accident, the saw cut the power cord. It's long cable and I want to save it. My method keeps the cable lean and retain it's strength. It's not water-proof, but I never use a pole saw in a rainy day.
on May 31, 2019 | Electrical Supplies
If you make your point of reference the flywheel (starter side) of the motor then rotation is clockwise. If your point of reference is the alternator or the end opposite the motor flywheel, then it will be CCW.
Electric... | Answered on Apr 26, 2019
If you use a car battery you cannot go wrong. Jumper a car battery!
Electric... | Answered on Apr 10, 2019
Go to google put in the item you're looking for and it will be there for you
Electric... | Answered on Feb 21, 2019
There are many ways to start. First, the starter is weak, and the second is that the starter does not move. If the latter, check the controller for signal output. If there is no signal output, check the battery for voltage? If there is pressure, the controller may be broken.
Electric... | Answered on Dec 19, 2018
Electric General  Ted134050 50a 480v Circuit Breaker Logo
2 questions posted
Top Electrical Supplies Experts
Fahr Quad
Muntejaya Ginting
Muntejaya Ginting
epangan29
Are you an Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
Electric Electrical Supplies
  • Electric Electrical Supplies
Most Popular Question
major cirsuit breaker blew
  • Electrical Supplies
