20 Most Recent Panasonic SR-CG05NW 3-Cup Rice Cooker Questions & Answers
How to reset the clock in sr-ck05
Panasonic... • Answered on Feb 17, 2014
i have just stripped mine down to replace the centre spindle - and i can see how to get at the nut on the back of hte pan to remove the insulator. remove the two screws for the mains bracket- then the four screws for the feet - the five at the top come next - just to be on the safe side remove the left hand screw from the lid and angle it backwards carefully and slide the lid off to the right - you now have a fight to get the front display off by raising the whole of the pan and top and rotating the electronics section to the front - at some point it will give and you will think you have broken it - but hopefully you haven't - you now have to remove the mains cable clamp or you won't be able to get the pan out - so with a screwdriver carefully lever the outer smaller side and then the other side - it will pop out of the bracket and you can feed the mains cable through the bracket - allowing you to remove the pan - you will see the nut on the outside of the pan to be able to remove the insulator there will be images and a full run through on my site at https://filsphilosophies.stan-tech.com/ i went on to replace the spindle and there is an article on replacing the paddle spindle - if your bread doesn't rise as it used to then this is the part to replace - and it will be like new again giving you bread risen to the top or over.... reassembly is the reverse of taking it apart good luck
Panasonic... • Answered on Mar 28, 2020
Https://www.google .com shows online sale of replacement paddle in October 2012.
Panasonic... • Answered on Jan 06, 2019
Request manual directly from Panasonic.
Panasonic... • Answered on Nov 02, 2018
Have you checked the plug in for continuity? Does not usually happen, but it could. If you have a meter, check for current before the fuse. If you have current, then there is another kind of fuse in modern appliances. It is called a diode. If you can get the wiring diagram, look for the diode. It keeps current from flowing backwards when there is a spike in voltage. It is a kind of fuse but that is not its entire use in the circuit. It keeps the whole circuit from being slagged. It is worth checking or getting someone to check it for you. Let me know and we can go from there.
Panasonic... • Answered on Oct 23, 2018
Good choice, they are one of the best. Choose one with an automatic raison/nut dispenser if you intend to make fruit or seed breads
Panasonic... • Answered on Jan 21, 2018
Panasonic SR-CG05NW 3-Cup Rice Cooker Logo
3 questions posted
Top Panasonic Kitchen Appliances - Others Experts
tina gallow
Vish Iyer
Vish Iyer
Are you a Panasonic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Kitchen Appliances - Others
Most Popular Question
use sr ck05 rice cooker
  • Kitchen Appliances - Others
