20 Most Recent
Panasonic SR-MM18NW Neuro Fuzzy 20-Cup Rice Cooker Questions & Answers
Panasonic SD-YD250 turns off in middle of cycle
Here are some possible reasons why your Panasonic SD-YD250 bread maker might be turning off in the middle of a cycle:
Power Interruption: If there is a power interruption during the baking process, the bread maker will turn off automatically. To avoid this, ensure that the power supply is stable and uninterrupted throughout the baking process.
Overheating: If the bread maker overheats, it will turn off automatically to prevent damage to the machine. Ensure that the bread maker is placed in a well-ventilated area and not near any heat sources.
Faulty Power Cord: If the power cord is damaged or faulty, it can cause the bread maker to turn off in the middle of a cycle. Check if the power cord is damaged or frayed and replace it if necessary.
Faulty Control Panel: If the control panel is faulty, it can cause the bread maker to turn off in the middle of a cycle. In this case, you may need to contact Panasonic customer support for assistance.
10/28/2023 8:29:37 AM •
Panasonic...
Answered
on Oct 28, 2023
Panasonic sd-yd250 does not mix raisins after the beep that signals the time you're supposed to put the raisins in
I'm sorry to hear that you're having trouble with your Panasonic sd-yd250 bread machine. It sounds like you're having an issue with the raisins not being mixed into the dough properly. There are a few things you can try to fix this problem.
First, make sure you're adding the raisins at the right time. Most bread machines have a beep that sounds when it's time to add mix-ins like raisins. You should add the raisins when you hear the beep, and not before.
If you're adding the raisins at the right time and they still aren't being mixed in properly, try coating the raisins in a little bit of flour before adding them to the dough. This will help them to incorporate more evenly into the dough.
Another option is to add the raisins after the bread machine has finished mixing the dough. Once the dough is mixed, you can remove it from the machine, stir in the raisins by hand, and then shape the dough and place it in the loaf pan. This will ensure that the raisins are evenly distributed throughout the dough.
I hope this helps! If you're still having trouble, you may want to contact Panasonic for additional assistance.
12/15/2022 11:21:50 AM •
Panasonic...
Answered
on Dec 15, 2022
How do I dismantle a panasonic SD-255 to repair it
i have just stripped mine down to replace the centre spindle - and i can see how to get at the nut on the back of hte pan to remove the insulator.
remove the two screws for the mains bracket- then the four screws for the feet - the five at the top come next - just to be on the safe side remove the left hand screw from the lid and angle it backwards carefully and slide the lid off to the right - you now have a fight to get the front display off by raising the whole of the pan and top and rotating the electronics section to the front - at some point it will give and you will think you have broken it - but hopefully you haven't - you now have to remove the mains cable clamp or you won't be able to get the pan out - so with a screwdriver carefully lever the outer smaller side and then the other side - it will pop out of the bracket and you can feed the mains cable through the bracket - allowing you to remove the pan - you will see the nut on the outside of the pan to be able to remove the insulator
there will be images and a full run through on my site at
https://filsphilosophies.stan-tech.com/
i went on to replace the spindle
and there is an article on replacing the paddle spindle - if your bread doesn't rise as it used to then this is the part to replace - and it will be like new again giving you bread risen to the top or over....
reassembly is the reverse of taking it apart
good luck
3/28/2020 8:27:12 PM •
Panasonic...
Answered
on Mar 28, 2020
