20 Most Recent Flotec FP0S2400A-03 1/3 HP 2,500 GPH Automatic Submersible Sump Pump Questions & Answers
Stopped working
The float is usually the culprit if it is not turning on. I f you have a floating ball type float switch try lifting it up and shaking it to see if pump starts running. These micro switches stick after several years use. If you have a round canister on the side it is a pressure activated switch that also has a micro switch inside that completes the circut when the pressure on the diafram is enough to click the switch. I f it has a float on a rod it has a switch at the top of the pump that shuts it off when at low level, and turns it on at high water level. Most pumps have a two part cord. The pump plugs into the float control switch, so it does not get power till the float switch clicks on. If you have a two part plug, then separate them and plug the cord in that leads directly to the pump body. This will tell you if the pump is working. If it is then replace the float switch assembly. Also there is either a few screws holding the pump screen on to the pump on the underside. Some simply snap fit to the pump body. Often I will find stones, wood chips string etc. in the pump impeller. That is what pumps the water by squeezing it into the small 1 1/4 output orifice. That about covers it. Please post to fixya.com if it does, so I get the credit for the solve. Let me know if you do need more advice. Good Luck!!!
4/8/2014 3:42:56 AM • Flotec... • Answered on Apr 08, 2014
I Noticed that there was
Maybe you installed the check valve upside down and the water will not pass through a check valve that is facing down instead of up. If you took the bottom strainer plate off the pump and cleaned it out in there, the pump impeller may have stipped its splines and consequently only the shaft turns. Usually I find small stones, string wood chips etc. that stop the pump. The breaker should pop if it is the proper amperage, when stopprd up with debris. Good luck. Hope this helps you solve your problem. Please post to fixya.com if it does, so I get the credit for the solve. Let me know if you do need more advice. I will be happy to give you the whole lowdow on sumps if you wish.
4/8/2014 3:14:16 AM • Flotec... • Answered on Apr 08, 2014
I need to adjust the pump. Currently I'm having to
Replace the float with either a pressure operated float switch, or a verticle float that has a rod in the center, Home Depot has ubiversal floats of all three variations.
3/29/2014 4:58:27 PM • Flotec... • Answered on Mar 29, 2014
HOW TO TURN ON PUMP??
The pump should start by itself and shut off by itself as well. The float switch needs replacing. If new, return it. If you want to test the pump, separate the two plugs and plug in the one that leads to the main pump body.
3/29/2014 5:11:23 AM • Flotec... • Answered on Mar 29, 2014
Canned motor pumps, single and multistage tripping
Replace the GBI breaker it is bad.
3/29/2014 5:04:09 AM • Flotec... • Answered on Mar 29, 2014
My basement waste flotec pump it stopped working
Flowtec shows manual for FPOS3200 with 3 year warranty, that looks very similar to your pump
http://www.flotecpump.com/resources/images/503.pdf
Flowtec help number
1-800-365-6832
FPOS3200 page
http://www.flotecpump.com/ResidentialProduct_fl_su_su_FP0S3200A.aspx
Flotec sump pump product page
http://www.flotecpump.com/ResidentialSearchResults.aspx#ProductType=Sump+Pumps
12/10/2013 3:29:52 PM • Flotec... • Answered on Dec 10, 2013
2answers
Pump keeps tripping the breaker... there's no
More than likely the pump motor is not sealed properly and the motor is getting wet. If you have warranty left take it back, as the problem could be severe. I have pulled these pumps apart and used silicone sealant on them, but it doesn't usually hold long if the pump has to run allot. Usually if the pump leaks into the motor, the body has been damaged or warped to the point that repairing them is pointless.
3/7/2011 5:39:11 PM • Flotec... • Answered on Mar 07, 2011
My dog chewed the power cord off my FPOS1800A-08
After searching, a clear answer was found ... if the cord replacement exists, it costs a lot.
Flotec has a contact-us form that requires your personal information
That being said, flotec FPOS thermoplastic sump pumps have pdf parts list.
Parts list shows cord as replacement part.
However, I don't see the FPOS1800 listed
http://www.flotecpump.com/pdf/FP0S6000A_08ReplacementParts.pdf
Flotec sell sheet shows FPOS1800 but does not show parts
http://www.flotecpump.com/pdf/Pg_6_2006.pdf
Website below sells flotec parts
http://www.pumpagents.com/FlotecPumps/flotec-pump-part-list.html
Random cordset price-check shows $46 for a cord
Another cord was $80
Another cord was unknown
11/15/2010 2:36:13 AM • Flotec... • Answered on Nov 15, 2010
Pumb only pumps a small amount out of the basin.
Flotec website shows several submersible sump pumps, and pump types:
http://www.flotecpump.com/asp/productapplication.asp?AId=28
Click product, then click on 'parts and literature' to access manual
Here is a Flotec manual:
http://www.flotecpump.com/pdf/FP525%2811-1-06%29.PDF
Manual for this type of sump pump says:
Quote from manual: Automatic float switch is sealed and factory adjusted for
most home sumps. Turn-on water level is 10" - 12" above
pump base. Turn-off water level is 4" - 6".
The manual also says that running the pump when dry will ruin the seals.
This implies that the water level setting is set so the seals will not be damaged
You might be able to dig the sump deeper, but I don't know if that meets your objective.
10/24/2010 10:30:02 PM • Flotec... • Answered on Oct 24, 2010
My pump died the other night. I took it all apart
Hello there:
The burning smell that you are smelling is the motor windings which means that the motor is shot
what probably happned is that the seals that seal the pump from the motor failed allowing the oil to get into the motor and as you know electricty and oil do not like each other so it fried the windngs on the motor ok
you can have the pump rebuilt for around $150 or just get a new one ok
I hope that this is very helpfull for you
best regards michael
10/30/2009 8:48:45 PM • Flotec... • Answered on Oct 30, 2009
2answers
Hey, I just had a
http://www.depcopump.com/datasheets/flotec/FP313-EN.pdf
Maybe your check valve is letting water go back down the well.
Troubleshooting steps pg 13 in manual list several things.
Check air valve for leaks.
Flowtec has a customer service number:
1-800-365-6832
The manual says: "Your new pump has a 30/50 PSI
switch, so adjust the tank pre-charge pressure to 28 PSI.:
But the manual does not say or show how to adjust pre-charge pressure.
The 30/50PSI means the pump turns on when pressure falls to 30, and then runs until pressure rises to to 50. So the switch is preset and not adjustable.
3/29/2014 5:45:13 PM • Flotec... • Answered on Mar 29, 2014
Don't have the model #s,
I would make sure that the pump is setting securely in the pit so that it can not move and hang the float up on anything.If you have a lot of trash or debris in the pit then unplug your pump and remove and clean regularly I have used bricks or wire to hold the pump in place to keep the float free.
One of the best pumps that I've sold for over 25 years is a little giant. They have a 1/3 H.P. model with the float secured on a rod hooked to the pump casing so it can only move up or down. Hope this helps. Thank you.
3/29/2014 5:18:07 AM • Flotec... • Answered on Mar 29, 2014
Pump comes on at 2.5
If the pump doesn't have an intergrated non return or check valve, then one has to fitted on the outlet side in the line to prevent back-flow of water, it sounds like there may also be something blocking the impeller?
Also check the polarity is spinning the pump in the right direction
3/7/2011 2:38:14 AM • Flotec... • Answered on Mar 07, 2011
Installed pump, ran for awhile
Out of ajustment buy hand move rod up and down if it works move rubber ring down alittle or up alittle Would help if I know what was on????
2/27/2011 2:56:46 AM • Flotec... • Answered on Feb 27, 2011
Manual for scorpion sl2800 generator
Yes
4/9/2024 2:32:16 AM • Electrical... • Answered on Apr 09, 2024
2answers
My conlog meter is showing the rfcon error please what do I do
No connecting to your utilty company in South Africa. Just FYI, we are a North American site and my not always have the answer, in this case we do Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error-cant-do-anything-on-the-gadget-please-help-on-how-to-re/962048393965724/ Quoting from link above: "Conlog Hi Ola-daniels, Please see below steps to assist with RFCON error : * Press the Back arrow on the keypad - this step is to refresh the UIU ( the device) * Type # 75 # - this is to check the signal strength If it does not go back to the normal display *Type # 80 # - this is to refresh the meter Then lastly you can repair the meter and the UIU by # 36 # The above steps will work better if you are outside the house because the meters uses the radio frequency connection The above error will occur in instances of bad weather conditions or if there is load shedding or power failure If the problem persists after trying the above you may contact the municipality or the service provider."
SOLVED: How do I clear up the rf con error on my meter ...
https://www.fixya.com > ... > The
May 7, 2020 - How do I clear up the rf con error on my meter because I want to ... Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error- ... Hi Ola-daniels, Please see below steps to assist with RFCON error : ... shut down the energy alimentation for 2 minute ,but if the defect persist error it show again. SOLVED: Pole meter conlog rf con meter keep on freezing ... Jan. 10, 2017 Meter reading shows rF CON instead of units available - Fixya Jun. 24, 2018 SOLVED: Good day my conlog ip54 elecricity meter showd ... Oct. 6, 2018 SOLVED: Rf con error - Fixya Jun. 20, 2020 More results from www.fixya.com
Please Help With My Conlog Prepaid Meter - Technology ...
https://www.nairaland.com > please-conlog-prepaid-meter
Aug. 6, 2020 - ystar: If the conlog meter is showing rf-Con, it means power supply doesn't reach the meter at all its either Loss of phase from the transformer or a loose contact ... How Do I Load The Activation Token On My Conlog Prepaid ... Mar. 17, 2020 I Need A Technician To Fix This... - Nairaland / General - Nigeria Jul. 22, 2019 I Need Number Codes To Reset Memmcol Prepaid Meter ... Jan. 11, 2019 More results from www.nairaland.com
3/24/2024 3:42:46 AM • Electrical... • Answered on Mar 24, 2024
Wiring 3 lights 3 separate switches
Consult a qualified electrician.
3/23/2024 7:13:23 AM • Electrical... • Answered on Mar 23, 2024
Flotec FP0S2400A-03 1/3 HP 2,500 GPH Automatic Submersible Sump Pump Logo
12 questions posted
Top Flotec Electrical Supplies Experts
CJ Rock
CJ Rock
Paul Katynski
Paul Katynski
Petrah Wanjiku
Level 1 Expert
Are you a Flotec Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Flotec Electrical Supplies
Most Popular Question
pumb only pumps small amount out basin
  • Electrical Supplies
