20 Most Recent Vector VEC010S Jump Start System 300 Amp starting power Questions & Answers
It takes time to charge the battery. Maybe you have an old battery, replace it.
Vector VEC010S... | Answered on Sep 06, 2017
I know how you feel because I had the same problem with mine until I read about the procedure.
Most of those Jump start chargers unfortunately require that you charge them when you buy it and then maintain the charge at least once a month.
There is usually a light on the charger to indicate that the charger is fully charged.
Vector VEC010S... | Answered on Mar 09, 2016
Go to battery spec.com look up battery jump start then click on vector jump starter battery is a TR9-12A
Vector VEC010S... | Answered on Dec 08, 2015
yeah from what im to understand... you charge it overnight, and yes another way to use it (and possibly better way) is connecting to the battery directly..... it should work on your van fine i think, its worth a shot, hope this helps :)
Vector VEC010S... | Answered on Mar 10, 2014
There may be just a wire loose, Also check radio shack for a rocker switch
Vector VEC010S... | Answered on Aug 22, 2011
This actually quite a good trick to provide an appropriate (eg. charged) 'alternate' DC power source to maintain the minimum voltage and current to hold the computer, radio and alarm setting for your car while swapping your car battery (I have myself used 2 small 9 Volts batteries in series via alligators clips for this purpose): just make sure that it is connected on the correct side of the cables where voltage and current will be maintained after the main car battery is disconnected!
Hope it works for you and have fun!
Vector VEC010S... | Answered on Apr 25, 2010
I got this off amazon.com i think it is the correct one, also went on black&decker to find the user manual, attached links.... the batteries on these things don't last long though good luck.
http://www.amazon.com/gp/product/B002V6VIZW/ref=pd_lpo_k2_dp_sr_1?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B000B794PY&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1NDZ7E054VC89M01SQ29
http://www.blackanddecker.com//customercenter/faq.aspx
Vector VEC010S... | Answered on Jan 10, 2010
Hi Ydja,
The batteries on these jump boxes don't last very long. I've been through three of them. Never again.
Now I just carry an extra battery. It's more powerful and has laste longer than the three jump boxes put together.
Best regards
Mike
Vector VEC010S... | Answered on Dec 12, 2009
Most likly the battery is old and will not keep a charge. I just replaced my battery for about $50 a few weeks ago. Go to a story like Battery + for a replacement. It worked for me.
Vector VEC010S... | Answered on Nov 10, 2009
Check that debris has not jammed the impeller. Small stone or piece of wood or wire, even a thick layer of sediment can prevent the impeller from spinning.
Electrical... | Answered 2 days ago
i think id be looking for a short. or maybe the breaker is bad
Electrical... | Answered on Sep 23, 2020
Simplest solution is to repair or replace the pull cord. Small generators are designed to be simple. The pull cord assembly and spring are usually a single combined part. They are usually fairly easy to swap yourself.
I suggest taking a close look at the starter motor - removing and testing it and while it is off check the engine will turn reasonably well by hand...
Electrical... | Answered on Sep 11, 2020
Vector VEC010S Jump Start System 300 Amp starting power Logo
Popular Tags
27 questions posted
Top Vector Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you a Vector Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Vector Electrical Supplies
Most Popular Question
vector 300 amps will not charge or hold
  • Electrical Supplies
