20 Most Recent
AMD Multimedia Computer with Athlon64 3000+ (2.0GHz)Processor (AMD64256BMDDR80GBHD) Motherboard Questions & Answers
While picture is shows blurring
Use VLC Media Player:
LINK
Scan for spy/malware using Combofix:
LINK
Scan for Registry Errors, Shortcut Errors using Advanced System Care 4.
LINK
Serials:
746F-746F-F0FF-2227 - 101Days
EABC-EABC-F0FF-E950 - 121Days
48F0-48F0-F0FF-0CD7 - 298Days
DFF7A-8204E-69ADE-0D5AA - 365Days
Disconnect your internet before insert your license key!!!
I've its a really old pc, you wont be able to play HQ-HD Movies.
Need the driver for amd athlon64 3000+ for windows
cnetdownload.com
on the home page you should see the download software finder under that there will be a list
platform
category
sub category
price
from the category drop down list select drivers
them from the price drop down list select free or which ever applies to your need
hope this helps dont forget to vote
I need sound drivers for my mother board compaq
You need to goto the manufacturers website, find
their support section and there should be a list of drivers for your specific
machine. Installing these should resolve your problem. I have a list of links
to most manufacturers drivers on my website.
Hope this helps,
www.PuterCare.com
Mouse jumping to bottom left corder randomly
What I'd try is go into the BIOS setup, and set your serial port for COM1 IRQ4 (Interupt) and 3F8H (address), if these latter notations are listed. Often, you will see the serial port, parallel port, etc. set to Auto.
You may want to see if the PS2 port can be set to a specific Interupt and address also, just as long as the settings are not in use by another device.
These kind of problems can be hard to pinpoint, but hopefully the above will solve your issue.
Long delays the first time ANYTHING is tried
Your symptoms sound like a slow hard drive. The first time you run Word or some other program the PC has to read the file from the hard drive into memory. You have enough RAM so that the program is still stored there till the next time you run the same program. When you run it again RAM is much faster so you experience the increased speed.
This is fairly typical behavior for a PC; in fact one of the big industry discussions right now is how Vista with its huge operating system is really going to strain the limits of traditional hard drives. While Word can take anywhere from 5 to 15 seconds to load on a typical PC Corel Draw is a much larger program and takes considerably longer.
Things that could affect your hard drive speed:
- It could just be an older hard drive. Generally the smaller the hard drive the older and slower it is. If you hard drive is smaller than 20 GB then an upgrade will boost your speed
- Your drive may not be configured to work as efficiently as it could. If you?re using IDE hard drives make sure the channel is running DMA not PIO.
- Your drive could be heavily fragmented. I?m generally not a big fan of defragging since the results are seldom worth it. In you case you may get enough of a boost to make a difference. Make sure you have a backup just in case something goes awry.
- Drive interface, IDE is the slowest, next is EIDE and the fastest is Serial ATA or SATA which is replacing IDE/EIDE on newer motherboards.
Where do I start computer upgrade
Your machine is very short of power required for win 10, I would like to see at least 8 GB ram, and a faster processor, yours is at the bottom of tests. Perhaps you should look at a new machine with win 10 installed. You cannot upgrade xp to win 10. You will have to purchase a win 10 license, you missed the free upgrade period.
