20 Most Recent
Kohler KOHGP51487 Authorized Original Replacement Part Tank Gasket For All Questions & Answers
How to replaceKohler Santa Rosa gasket
Shuit off water and remove the three bolts under the bowl in back lift off tank and remove gasket by pulling it off the bolts install new bolts inside tank install the white washers on the bolts then install them in tank and putr gasket on bottom of the tank and reinstall the tank to bowl and tighten down nuts be carefull not to over tighten bolts cause the bolts will snap the porecelain ears on the toilet.
11/30/2014 9:39:46 PM •
Kohler...
Answered
on Nov 30, 2014
Need step by step
Turn off the water to the fixture.
Flush the toilet and hold the handle down to let as much water out of the tank as possible.
Sponge the rest of the water out so the tank is dry.
Remove or undo the water supply tube from the fill valve.
Remove the three bolts holding the tank to the bowl and remove the tank.
Replace the old seal with the new one and reverse the whole process.
You should be good to go.
Good luck.
3/6/2011 11:38:31 PM •
Kohler...
Answered
on Mar 06, 2011
I replaced the triangular gasket
I usually use a small bead of silicon when I install Gaskets their for I am sure not to overtighten..........Hope this helps.
9/4/2010 11:31:50 PM •
Kohler...
Answered
on Sep 04, 2010
I have a Kohler toilet. The triangular black
Inside the tank it has a gasket from the stand pipe to the bottom of the tank. The stand pipe threads go through the tank and a plastic nut holds it to the tank. Then a gasket goes on the nut and threads to make a seal between the tank and bowl. I have included this picture that has the above look. I hope this will be of some help for you.
9/2/2010 9:10:18 AM •
Kohler...
Answered
on Sep 02, 2010
Replace gasket on a LG WM2077cw
can't tell you the part number but it's not to complicated. first shut off the water supply, then flush the toilet to get the water out of the tank, then remove the water supply line, then unbolt the tank from the bowl and replace the gasket. be carefull when tightening the tank back up, you want to do it evenly and only untill the tank is solid. or you can crack the tank
9/20/2009 10:30:53 AM •
Kohler...
Answered
on Sep 20, 2009
I need torque specs.for head and centerhead when
never have used a torque wrench to install toilet tanks. Put gasket on tank and insert bolts with rubbers washers through gasket and set tank on bowl in a level and straight postion and start nuts tightening them evenly until tank starts to snug to bowl. Hand tight is usually sufficient, you will see the rubber gasket and washers will compress to bowl and tank forming a seal (EVENLY) and tank will be firm to bowl. DO NOT superman torque these nuts! Compare the torque to finger strength on a wing nut. Hope this helps ,"if I understood the question."
7/7/2009 7:11:54 PM •
Kohler...
Answered
on Jul 07, 2009
Gas tank on a 2001 Camry with loose filler tube
Anything is possible, you could look to see if the fuel tank appears newer then the rest of the under body, however a new fuel tank is not such a bad thing, if it were installed properly...
3/11/2009 5:10:00 AM •
Kohler...
Answered
on Mar 11, 2009
Need password for a stolen file
Okay. The question is a bit lacking in details. Password for what? Password ON what? Where was the file stolen from? Who stole the file? What is the file content. What is the file extension (the bit after the file name and the period file_name.what)?
All questions need to start 'make model (what it is)' first 3 words. And then a clear question.
For the 13 people that have tagged this 10 year old question, it is better to post your own question.
2/7/2024 6:03:08 AM •
Kohler Home
Answered
on Feb 07, 2024
