20 Most Recent RTO Bock Water Heaters 32E 32 gal 104,000 3/4" 3/4" 0.75 Questions & Answers
The nozzle size and gap completely are designed to each burner, if the bock water heater had a becket burner than you would be okay with the gap, if not then what I would do is check the manufactures manual for proper nozzles and gaps of electrode assembly
RTO Bock Water... | Answered on May 29, 2017
If I understand correctly, your Bock gas water heater vent is causing water to leak down into chimney.
This is a very serious concern
Water leaking from water heater flue indicates improper venting.
The hot air gasses from water heater combustion contain water vapor, but the gas should vent out of house before condensate forms on pipes.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#flue
The problem might be caused by a power vented furnace that pushes vent air from furnace down into flue pipe for water heater. As a result, the water heater doesn't vent properly.
There could also be a clog.
Light a match under water heater draft hood and see if smoke from match travels instantly upward.
There are two major concerns.
1) If vent is not working, it means that odorless CO gas is entering home instead of venting outdoors.
CO carbon monoxide is deadly poison.
http://en.wikipedia.org/wiki/CO_poisoning
You can buy CO detector after vent is repaired.
2) Water condensate will eventually rust away vent pipes because of acidic content of the combustion vapor. It can be expensive to replace pipes, and pipes with holes pose risk of CO poisoning.
My suggestion is call a qualified plumber ASAP and explain what you observe.
Plumber will want to inspect the vent pipes, and may want to extend water heater vent pipe up further inside chimney so furnace is not pushing air back into water heater vent.
Plumber may also find blockage somewhere in the vent stack or chimney.
Also post on a professional water heater forum like the Tank to double check anything the plumber says to you. These are the pros.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
RTO Bock Water... | Answered on Oct 28, 2013
These anode rods, sometimes made from aluminum, prevent corrosion. The rod emits ions that line the tank and help prevent corrosion. The rod isn't solid magnesium or aluminum; it has an iron core. If your hot water smells of sulfur (rotten eggs), the anode rod has gone bad or there is a presence of hydrogen sulfur gas that is overwhelming the rod. Usually replacing the rod will stop the odor, but sometimes chlorination of the tank is necessary.
RTO Bock Water... | Answered on Oct 25, 2011
1) Anode rod is located on top of water heater.
It is 1-1/6" hex head.
It might be under a plastic plug, or you might have to take off metal top of tank.
Sometimes you cannot remove anode rod because it is rusted too badly.
I have used impact wrench sometimes and been unable to budge them.
2) Open following links for anode illustrations and resources:
http://waterheatertimer.org/Replace-anode-rod.html
http://www.thisoldhouse.com/toh/video/0,,20047047,00.html
3) Rusty water implies that anode is bad.
But water released by TP valve implies overheating, or bad TP valve.
4) Replace TP valve.
http://waterheatertimer.org/How-to-replace-TP-valve.html
5) Check your burner and combustion parts for orange-or-yellow flame and sooting on parts that implies the water heater needs to be cleaned. You do not want overheated combustion chamber to cause ECO event that might require new gas control thermostat.
Gas should burn with clear blue flame.
6) Overheating tank can also imply that gas control valve thermostat is not working correctly and may soon fail. This would be evidenced if water is very hot and new TP valve doesn't stop hot water release.
7) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
RTO Bock Water... | Answered on Sep 04, 2011
This has to be one of two problems....
Either the dip tube is not in place properly or the hot and cold are reversed....
That is the ONLY way that you can be having that problem....
Make sure you have another person look at the heater...
Take off the piping on both the hot and cold lines and VERIFY that the dip tube is in place in the cold side, and that there is NO dip tube in the hot side....then also that the pipes are connected correctly...
heatman101
RTO Bock Water... | Answered on Apr 08, 2011
There are many things that could be wrong with an oil fired hot water heater...oil burners are not something that a novice should mess with as they can be very dangerous...
Please hire a por to figure thsi out for you..
heatman101
RTO Bock Water... | Answered on Feb 03, 2011
Brand does"nt matter use .75/80degree hollow
RTO Bock Water... | Answered on Jan 11, 2011
Check the power supply.
Check the thermostat control.
These can be checked with a volt meter.
RTO Bock Water... | Answered on Dec 22, 2010
Hello You have a clogged oil filter or oil line.The (electrode) gap should be left ALONE.The line needs to be blowin out & replace the filter element then the flameout will stop.
RTO Bock Water... | Answered on Sep 04, 2010
Bad faucet cartridge:
walk-thru on following link
http://waterheatertimer.org/Crossover.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
RTO Water... | Answered on Oct 29, 2017
What water pressure reading do you have? IS there a mixer in the system? What is the exact model number?
RTO Water... | Answered on May 04, 2013
RTO Bock Water Heaters 32E 32 gal 104,000 3/4" 3/4" 0.75 Logo
21 questions posted
Top RTO Water Heaters Experts
Mike
Bill Johnson
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
View Most Popular
RTO Water Heaters
  • RTO Water Heaters
Most Popular Question
bock
  • Water Heaters
