20 Most Recent Omega Reliance& Electric Compact Water Heater Questions & Answers
3answers
Omega tankless water heater giving error code E2 incomplete burn
it sounds like your flu pipe may be clogged,, they just snap together or have little screws holding them together,, take the sections apart and make sure nothing is is the line reinstall and try it out
11/16/2015 11:06:06 PM • Omega Reliance&... • Answered on Nov 16, 2015
Gas smell when it ignites
You have a gas lick or the igniter rods are too fare apart . You have 3 needles on the top of burner.The one in the meddle is the ION sensor . The two on the ends (the one's bent at 45 degree on the end!) are the ignition rods. Also check if you have spark at both rods and if the thick black wire are securely connected .If you have more questions about it you can go to their webpage and contact them with a email. Response will be the same day, some time with a link to a Utube video explaining the fix.
2/1/2013 11:48:54 AM • Omega Reliance&... • Answered on Feb 01, 2013
0answers
Where can I get a Service Manual including error codes, of HITACHI Package unit RUA-30AT3S?
I am not sure they are available to non Hitachi service centres. https://documentation.hitachiaircon.com/glb/en/pac/rua-at3s
3/17/2024 4:06:16 PM • Water Heaters • Answered on Mar 17, 2024
VAILLANT ECOTEC PLUS 831 BOILER , with an error code of F79, which is not in the handbook, its not working at the moment, already had a local plumber out, who didn't know a lot about F79 code
Cannot find the fault code . There are vidoes on u tube saying how to reset thr code By pressing the reset button . If this does not work youcan ccontact vaillent on there web page . I have a mate who works for them i will ask him as well
2/12/2024 9:14:32 PM • Water Heaters • Answered on Feb 12, 2024
2answers
Envirotemp water heater
Do I need to insulate this heater out in the shed? Freezing temperatures
2/6/2024 11:45:03 AM • Water Heaters • Answered on Feb 06, 2024
Remeha avanta plus combi problem
Call a engineer
1/11/2024 7:52:09 PM • Water Heaters • Answered on Jan 11, 2024
What is error code c8 mitsubish heater
The P8 fault can mean many things when it pops up on your Mitsubishi Electric wall controller. The P8 fault is activated when the indoor coil sensor does not change the temperature for a set amount of time after the compressor is (or should be) switched on.
12/26/2023 4:41:20 PM • Water Heaters • Answered on Dec 26, 2023
How to replace digital thermostat on Amtrol boilermate to a manual thermostat
Where does the tube sensor go
12/23/2023 12:54:29 AM • Water Heaters • Answered on Dec 23, 2023
10 year old Richmond 40 Gallon water heater, cannot move knob to ON/OFF or Pilot. Pilot light is out.
call plumber to replace gas valve, it may cheaper replace water heater. gas valve is not DIY
12/1/2023 6:48:46 PM • Water Heaters • Answered on Dec 01, 2023
My boiler doesn,t always switch off when programe is off
test for sticking relay faulty circuit board or faulty stat
10/28/2023 4:42:20 PM • Water Heaters • Answered on Oct 28, 2023
Rival titan floor heater coils don't turn red
Beware when working with electrical equipment. It may cause electric shock. Check the power supply wires, connections with heating coils. If they are ok then possibly heating coils require replacement.
10/17/2023 2:53:24 PM • Water Heaters • Answered on Oct 17, 2023
3answers
Where on a sunday do I find a GS640YBVIT heater?
I would try their website; www.statewaterheaters.com They should show a list of their service agents.
8/28/2023 6:22:14 PM • Water Heaters • Answered on Aug 28, 2023
How do I bleed the pump? It's running but not circulating water after partially draining the hot water heater.
Domestic Central Heating, Dodge Caravan, well pump or a Pool Heater, or something else. All questions need 'make model (what it is)' as first 3 words. With the exception of the Dodge Caravan, pumps have a small bleed screw. Google make model bleed pump or if it is an above ground well pump make model prime pump This is heavily weighted towards vehicles, but you will get the ideal of the power of Google! https://www.google.com/search?q=%E2%80%8Bmake+model+bleed+water+pump ..
5/17/2023 10:56:35 PM • Water Heaters • Answered on May 17, 2023
Towerchron QE2. Timer set up ok. Room thermostat set 25. Timer lights ok at set timings. Boiler will not come on
Call for Service. The timer is fine, the boiler has failed. I presume it is gas fired, which means that only gas registered service techs can work on it.
4/16/2023 10:15:58 PM • Water Heaters • Answered on Apr 16, 2023
Energy smart water heater has start up failure
Energy smart water heater has start up failure problem so how to resolve
3/26/2023 5:11:27 PM • Water Heaters • Answered on Mar 26, 2023
Omega Reliance& Electric Compact Water Heater  Logo
Popular Tags
3 questions posted
Top Omega Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you an Omega Water Heater Expert? Answer questions, earn points and help others
View Most Popular
Omega Water Heaters
  • Omega Water Heaters
Most Popular Question
gas smell when ignites
  • Water Heaters
