20 Most Recent Polder Slimmer Digital Scale Questions & Answers
There is a button on the back of the scale with "g/oz" below it. This changes your scale from grams to ounces or vice versa.
Polder Slimmer... | Answered on Mar 08, 2019
I had the same problem, I am not sure why but it seems like the circuits misfire when you change the batteries (perhaps a capacitor holding a charge or a diode stuck).
I got mine working again when I put the batteries in backwards (trying to discharge any capacitor that might be holding a small charge still) and then hit the power button with the batteries in backwards; then put the batteries in properly and hit power again.
please note that I am NOT an electronics professional and I have no idea if this is harmful to the scale or not, but it worked for me and the Polder scale is working as designed once I did the procedure. Hope it helps.
Polder Slimmer... | Answered on Sep 05, 2018
Batteries can be changed on almost all instant read thermometers
go to POLDER.COM/ support/
then choose then choose
Thermometers
and then enter your model #.
This should take you to a detailed explanation. In general look at the unit and find the place to gently pry the cover apart. remove the batteries and replace with the same new style.
Polder Home | Answered on Aug 13, 2014
Hi....did you ever find and answer to this? mine is doing the same thing? I need help--wondering what you did to fix. thank!
Home | Answered on Aug 31, 2020
the little handle shower it's easy to break , chaek it and order new one , easy to replace
Home | Answered on Aug 30, 2020
cheak the spring for hold the batteries , be sure put batteries in right directions +++---
Rotate hr hand until it chimes the hr then remove hr hand and replace to the hr position then check it chimes at the correct position
Home | Answered on Aug 27, 2020
This type of specific parts are difficult to get in the local hardware shop but one can try in some big online store like Amazon. So many resellers are attached to them and someone might pick up that order and deliver. It is worth trying.
Home | Answered on Aug 23, 2020
Polder Slimmer Digital Scale Logo
Popular Tags
5 questions posted
Top Polder Home Experts
john h
Tom Chichester
Are you a Polder Home Expert? Answer questions, earn points and help others
View Most Popular
Polder Home
  • Polder Home
Most Popular Question
thin kitchen scale after changing
  • Home
