20 Most Recent
Jet Equipment Chain Hoist 1TON 10 Ft Lift #111000 Questions & Answers
Manual chain hoist keeps slipping load chain when
sounds if the motor brake is not holding , this is a wear part and will require adjustment/replacement over its life time , the brake is located under the motor cover , but if your not sure what to adjust ,then im gonna suggest for safetys of you and the people around it' s sake you get a profesional to service this hoist
How to wire
use a wireless controller it will be cheaper and easer http://www.telecrane.com/
the three wires are
x1 constant power
up
down
x1 is connected to the up or down wire to activate the hoist in the desired direction
Therma Overload Switch
If you have not supplied enough power (like using an extension cord) the motor sees a big voltage drop, starts drawing a lot of current and eventually overheats. Make certain to use a good supply.
JET Tools
2/5/2015 9:19:38 PM •
Jet Saws
Answered
on Feb 05, 2015
How do i adjust the blade tilt
There should be 2 handles: height and tilt. Tilt is typically located perpendicular to the blade on the base of the saw.
1/28/2015 8:38:11 AM •
Jet Saws
Answered
on Jan 28, 2015
How do i adjust a jet bandsaw jwbs-9 blade tension
You should check your manual. There's a blade tension handle on my bandsaw, which is adjusted every time I need to change tension or change blade. There ways how to check the correct tension, you can pluck the blade like a string on a guitar and if you hear music not like sound, tension is good. Or you can follow the suggestion blade tension on your saw. or you may also use tension gauge.
7/25/2014 6:53:18 PM •
Jet Saws
Answered
on Jul 25, 2014
