20 Most Recent
Makita Circular Saw - 15 Amp, 7 1/4in. Dia., Model# 5007FAK Questions & Answers
Saw cuts bevel at 0
Check that the bed of the saw (the flat metal part on the bottom) isn't bent. I've had this sort of thing happen on a jigsaw that needed to be tapped back into square. Check the squareness of the saw with a framing square or a carpenter's square held against the blade and the bed of the saw with the blade guard open. Obviously, make sure the saw is unplugged before doing this.
Blade stops when you start to saw
If the motor still runs you might have a problem as simple as a loose blade bolt, missing flange or worse a gear/armature problem, if the motor quits then you have an electrical problem that would need to be diagnosed, get back to me with either one and I will try and help further.
Motor arcing and smell of burning
you have a major electrical problem, unplug tool and remove the brushes to check their condition. Rotate the blade by hand and look for any unusual wear pattern or discoloration. This would indicate a failure and the appropriate parts would need to be replaced.
Hello i need to know : circular saw need to oiling
the gearcase for this saw is under the blade and you would have to remove the blade and the screws holding the gearcase cover in place. There is a small amount of GREASE in this cavity. If you want to replace the grease use a small amount of white lithium type grease. DO NOT pack this area full or you will cause more damage. Let me know if you need more assistance and if you give me the model and brand I will locate a breakdown for you so that you know what is involved.
I have a makita 2703
First thing I would check are the Carbon Brushes. The are # 75 in the picture
Hope this answers all your questionsPlease remember to Rate/vote for any solution that helps you out.Thanks for using Fixya.
10/12/2022 4:35:39 AM •
Makita Saws
Answered
on Oct 12, 2022
