20 Most Recent Uniden TRU546 Remanufactured Dual Handset Powermax 2.4 GHz Cordless System with Digital Answering S... Phone (TRU546R) Questions & Answers
Unplug the power supply to the base of the main handset, wait 10 seconds and plug back in.
Uniden TRU546... | Answered on Jan 13, 2015
go to the phone's menu for announcements, select custom announcement.
Uniden TRU546... | Answered on Jun 18, 2009
Power Off and Power On the system and the handset System first
Uniden TRU546... | Answered on Apr 19, 2009
Call the phone provider you are using, (verizon, att, etc.) they can help you to reset the password.
Uniden Lands... | Answered on Mar 27, 2020
Hello Lynn:
Make sure the power cord is securely plugged into the telephone base. Plug the telephone base into a different working electrical outlet not controlled by a wall switch. Move the handset closer to the telephone base. It may be out of range. Reset the telephone base by unplugging the electrical power to the base. Wait for 15 seconds and plug it back in again. Allow up to one minute for the cordless handset and the telephone base to synchronize. Other electronic products such as HAM radios and other DECT phones can cause interference with your cordless phone. Try installing your phone as far away as possible from these types of electronic devices.
Do not disturb or silent mode may have been enabled. Without the model number of your phone, I might miss one of the ways to re-enable ringing for your model. Make sure that the phone is in standby mode. Next, check if there is a DND button on the base for the cordless phone system. If the LED for the button is lit, press that button. You may need to hold the button; enabling Do Not Disturb requires a press and hold.
To disable silent mode, press and hold Silent on either the handset or the base. On the handsets, this may be the # key (below the 9). When you enable Silent Mode, you can get a prompt for how long you want the phone to be quiet. If you do not press any number key (other than 0), the Silent Mode will last until you disable it manually. You can then confirm the Silent Mode or it will be enabled after 5 seconds.
I hope this helps. In both modes, the answering system will automatically be turned on if it wasn't on before enabling the mode.
Uniden Lands... | Answered on Jan 30, 2020
REPLACE IT WITH A NEW PHONE
Uniden Lands... | Answered on Nov 13, 2019
message light
press menu
scroll to settings then to global settings press menu scroll to vmwi and press enter
scroll to yes , press menu then end
most started after changing to NBN
Uniden Lands... | Answered on Nov 10, 2019
Select the channel, press 0, press E
Uniden Lands... | Answered on Nov 06, 2019
You don't state if the unit is on charge when it happens, or if it is all the time. You also do not state what model, and Uniden makes hundreds of products. But, it is probably an inadequate load on the charger, which would mean the battery is toast.
Google (uniden)(448-2)(manual) without parens for time setting instructions.
Uniden Lands... | Answered on Aug 21, 2019
Uniden TRU546 Remanufactured Dual Handset Powermax 2.4 GHz Cordless System with Digital Answering S... Phone (TRU546R) Logo
13 questions posted
Top Uniden Lands Phones Experts
Marvin
Marvin
martin hogg
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
Uniden Lands Phones
  • Uniden Lands Phones
Most Popular Question
uniden powermax 5 8 system busy error
  • Lands Phones
