20 Most Recent Seeds of Faith Cycas revoluta - "Sago Palm" tree 10 seeds Questions & Answers
Usually once every year or two, Sago Palms bottom frond will die off in order to produce new ones that shoot out the top. Once they die you can pull them out with your hand because the fibers that attach them are also dead.
Seeds of Faith... • Answered on Mar 03, 2015
Cannot date it from that. Talk to Evinrude or your local ships chandeller.
Garden • Answered 4 minutes ago
the bottom pan gasket is probably blown. or the main seal. wipe it off real good and start it you will see where it is coming from
Garden • Answered 20 hours ago
MS1432 seems to be a good match for the mac 3200 (at least the Mac 3200 I just aquired from Pawn Xchange is identical to the MS1432 that was swiped from me last year by an *EX* friend) - PDF here:http://lawnandgarden.manualsonline.com/manuals/mfg/mcculloch/ms1432.html?idRes=5629277(Yeah, I know, this is an old question but, it may help the nest person needing a manual)
Garden • Answered 3 days ago
Hand axe is a small axe used for intermediate chopping, similar to hatchets.
Contact Shur Dry directly to inquire.
Garden • Answered on Jun 19, 2021
1. Weak motor 2. Binding or damaged line Mechanism
Is this a 4cycle blower or 2 cycle ? if its a 2 cycle the baffle plugs up from low grade 2 cycle oils, so he prob. pulled it out because your eng would not rev up cause of it being plugged, he should be able to find you one, personally I would run with it the way it is...the better your eng breathes...the better it runs!
Garden • Answered on Jun 18, 2021
Do you know the belt size for the poulan 25972 mower
Garden • Answered on Jun 17, 2021
Hi randal book..Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly seat the idle mixture screw and high speed needle adjusting screws. Be sure to write the number of turns down on a piece of paper so you will know how many turns from the seated position to open the jets when you go to reinstall them, or if you remove them for cleaning or replacement.If you have aready tried to adjust them then the adjustments below should get it running for you for final adjustment when warm.Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm. Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.Alway use the "lightly seated" method if you have not changed the screw settings.Please take time to rate me Bud
Garden • Answered on Jun 15, 2021
Go to SearsPartsDirect.com they should have what you need if not try eReplacementParts.com
Garden • Answered on Jun 14, 2021
Try here...
https://www.cmsnl.com/yamaha-yt3600m-front-engine-lawn-tractor-1988_model9441/partslist/C-09.html#.YMdCaVMpCdM
Turn (twist) the spray arms so the spray head rotates in the opposite direction.
Garden • Answered on Jun 13, 2021
The belts may be loose.With the mower off,engage the blades and check the tension.Next would be to get under the mower and check for debris in and around the lever that engages the blades.Sometimes trash will get hung up in there and the blades will disengage.The next step would be to inspect the pulleys for debris and to make sure the spindles are not bent.While at the pulleys make sure there are no burrs or cacks in the pulleys,as that will cause the blades to disengage.
Seeds of Faith Cycas revoluta - "Sago Palm" tree 10 seeds Logo
1 questions posted
Top Seeds of Faith Garden Experts
john h
wadingriver
wadingriver
ray gallant
Are you a Seeds of Faith Garden Expert? Answer questions, earn points and help others
View Most Popular
  • Seeds of Faith Garden
Most Popular Question
pull out brown fronds hands sago palms
  • Garden
