20 Most Recent
Fantom Vacums FM625H Vacuum Questions & Answers
How does one get the belt off of the FM625H? My
I sat down and studied the brush and mashed the two levers on the
front and it came apart. But I am not having any luck finding
the right size belt. I called the 800 number and got a guy wanting
my life history and I never got a number. Thanks
Vacuum hepa gets hot
Carol,
Have you checked to make sure that all of the filters have been cleaned so that you have good air flow? The HEPA filter is your final exhaust filter and if your motor is getting hot because of poor air flow, it will cause the HEPA filter to get hot as well. Hope this helps!
Manuals vax
Check the fuse, replace if blown WITH SAME RATING FUSE. If there has been any damage caused to the cable, have this replaced by A QUALIFIED ELECTRICIAN.
Need an on/off switch for a Fantom Upright FM741B
Try these:
http://outdates.ecrater.com/http://www.blujay.com/outdatesIf no luck there, any power switch from another 120V product should work as long as the wires match. If you have a normal 2 wire switch, you should be fine. Be sure the amps on the new switch match the old and the terminals are the same size (don't try to force a small terminal onto a large one). Also, be sure that if you use another switch, be sure the terminals are wrapped or protected to keep them from shorting out if they were to fall off. With a little plastic modification, you sure can fit a square switch into a round hole lol. Good luck.
