20 Most Recent Black & Decker 400 Watt Electromate With Radio #PS400JRB Questions & Answers
Just to play it safe I would NOT jump start while charging, It sounds like one would be putting out too much volts/amps ETC and could damage or the even kill the battery.
Black & Decker... | Answered on Oct 02, 2016
Did you try this?
Fuse Replacement (DC Accessory Adapter)
1. Remove plug from accessory outlet. Remove the gold cap by turning counterclockwise
and lifting off.
2. Remove center pin and spring. Remove fuse.
3. Replace fuse with same type and size fuse (8 amp).
4. Replace center pin and spring inside plug.
5. Replace gold cap by turning clockwise.
For assistance with your product, visit our website www.blackanddecker.com for the
location of the service center nearest you or call the BLACK & DECKER help line
at 1-800-544-6986.
Black & Decker... | Answered on Mar 20, 2016
  1. Unsnap the black plastic tray on the bottom. Turn the unit face down. Loosen four screws along the bottom edge.
  2. Loosen two screws in the handle and one screw on each side.
  3. Use flat blade screwdriver to pry up black rubber bumper near the top (back side only) and loosen one screw underneath on each side.
  4. Open the flat panel, remove any contents and loosen two screws at the back.
  5. With all 12 screws loosened turn unit face up with bottom toward you and gently pry bottom apart. There are wires and tubes connected inside so just prop it open enough to work.
  6. Replace battery ($29 + shipping on Amazon, search on battery model like CB19-12 or EXP1218).
  7. Reassemble.
  8. Tell spouse you just saved $150; collect reward.
Black & Decker... | Answered on Mar 14, 2015
I went to the Black & Decker site and downloaded the pdf manual of the electromate 400. It says you're supposed to charge it until you have one red light, one yellow light, and one green light. I expect that 2 red lights and a green light means it's not fully charged. The manual also said you can't overcharge using the 120 V. method. Good luck.
Black & Decker... | Answered on Apr 04, 2013
Fix expedtion
Black & Decker... | Answered on Sep 15, 2011
I just bought one similar and wondered the same thing. on the unit you will find two male prongs recessed into the case. Simply plug and extension cord into them, the 12v charger is built in. Mine said to charge for 36 hours before fist use.
Black & Decker... | Answered on Mar 03, 2011
Why does the AC indicator light constantly flash and I have no AC power on my Black and Decker Electormate 400
Black & Decker... | Answered on Oct 25, 2010
What are you talking about? You don't mention the electrical item.
Black & Decker... | Answered on May 23, 2009
Black & Decker 400 Watt Electromate With Radio #PS400JRB Logo
27 questions posted
Top Black & Decker Tools & Hardware - Others Experts
efs_perpends
efs_perpends
Edward
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Black & Decker Tools & Hardware - Others
Most Popular Question
manual black decker electromate 400
  • Tools & Hardware - Others
