20 Most Recent
Tascam Midistudio 644 Questions & Answers
No voltage on motor after replacing belt Tascam Midistudio 644
The issue with the voltage regulators getting hot and the motor not receiving any voltage after replacing the belt on your midi studio could be caused by several factors. To resolve this issue, you can try the following steps:
- Check the wiring: Make sure that all wiring connections are secure and that no wires have been damaged or disconnected during the belt replacement.
- Check the voltage regulators: The voltage regulators could be overheating due to a short circuit or incorrect voltage. If they are hot to the touch, disconnect the power immediately and replace them with new ones if needed.
- Check the motor wiring: The motor may not be receiving voltage because of a wiring issue. Make sure that the motor's wiring is connected securely and that the voltage is present at the motor's terminals.
- Check the power supply: The power supply may not be providing enough voltage to power the motor and voltage regulators. Make sure the power supply is functioning properly and providing the correct voltage.
If these steps do not resolve the issue, you may need to seek further assistance from the manufacturer or a professional repair service. It is important to handle electronic components carefully and to follow all relevant safety guidelines to avoid damage or injury.
1/29/2023 12:37:14 PM •
Tascam...
Answered
on Jan 29, 2023
We have car audio that requires code, do you know the options how to unlock it?
If your car audio system requires a code to unlock it, there are a few options you can try:
Check the user manual: The user manual for your car audio system may contain information on how to unlock it if a code is required. Look for a section on "security" or "anti-theft" features.
Contact the manufacturer: If you don't have the user manual or can't find the information you need, you can try contacting the manufacturer of the car audio system. They may be able to provide you with the code or instructions on how to unlock it.
Try common codes: Some car audio systems use a default code, such as 0000 or 1234. Try entering these codes to see if they work.
Reset the system: If none of the above options work, you may need to reset the car audio system. This will erase any saved settings and data, including the code. The process for resetting the system will vary depending on the make and model of your car and audio system. Check the user manual or contact the manufacturer for instructions.
Working on a Rock-Ola 488 Jukebox. Looking for a block diagram of power distribution
Unfortunately, I do not have access to specific diagrams for the Rock-Ola 488 Jukebox. However, a typical power distribution block diagram would show the power source, such as the power supply, and the different branches of distribution to various components. These could include the amplifier, control circuits, motors, and lighting.
In your case, since you only have the power supply and power amp, you could start by tracing the power wires from the power supply and identifying which wires connect to the power amp. Then, you can look for any other components in the jukebox that require power and trace their wiring to the power distribution network. This should give you a general idea of how power is distributed throughout the jukebox.
Proton D940 stereo receiver. What kind of CD player and cables do I need to hook it up to the car?
The Proton D940 stereo receiver features both analog and digital inputs, so you have a few options when it comes to connecting a CD player to the receiver.
For a digital connection, you will need a CD player with a digital output, such as a coaxial or optical output, and a digital cable to connect the two. Look for a CD player with a digital output labeled "coaxial" or "optical" and purchase a cable that matches the output on the CD player and the input on the receiver.
For an analog connection, you will need a CD player with analog outputs, such as RCA outputs, and an RCA cable to connect the two. Look for a CD player with an analog output labeled "RCA" and purchase an RCA cable with the appropriate connectors to match the CD player and the receiver.
Once you have the CD player and cables, connect the CD player to the Proton D940 stereo receiver using the appropriate input on the back of the receiver. If you are using a digital connection, select the appropriate digital input on the receiver using the input selector button on the front of the receiver. If you are using an analog connection, select the appropriate analog input using the same input selector button.
Cq-vd6505u Car DVD
You can try to hold the right round selector knob to the right for 10 seconds while unit is on asking for code input. That will work to unlock if the previous owner did not set the 4 digit code. Good Luck
How do I reset a TRP am/fm cd player. When i turn it on it says P55 2001
This is an old question but I recently had the same problem. The owners manual says to press and hold the band and preset 1 buttons simultaneously. This did not work for me. I removed the radio from the dash and pulled the fuse on the back of the radio. Replacing it after a few seconds reset the radio.
My pure cd player keeps changing source to AUX. How do I stop this from happening.
If your Pure CD player keeps changing source to AUX, it may be due to a few different reasons. Here are some troubleshooting steps you can try:
- Check the connections: Make sure that the cables connecting your CD player to your speakers or amplifier are securely plugged in. Loose or faulty connections can cause interruptions in the signal and trigger the player to switch to AUX mode.
- Clean the input selector switch: If your CD player has an input selector switch, dust and debris may accumulate over time and cause the switch to malfunction. Clean the switch using a can of compressed air or a soft-bristled brush.
- Check the settings: Some CD players may have settings that automatically switch to AUX mode when no signal is detected from the CD player. Check your user manual to see if your CD player has this feature and how to turn it off.
- Reset the CD player: Turn off your CD player and unplug it from the power source for a few minutes. Then, plug it back in and turn it on to see if the issue is resolved.
- Contact the manufacturer: If none of the above solutions work, it may be necessary to contact the manufacturer's customer support for further assistance. They may be able to provide additional troubleshooting steps or arrange for a repair or replacement of your CD player if necessary.
Note: Before attempting any maintenance or repair work on your CD player, be sure to read the user manual thoroughly and follow any safety precautions.
It i stuck on the cd button and I can not get it to change
If your device is stuck on the CD button and you're unable to change it, try the following steps:
- Check the device's manual: First, consult the manual for your device to see if there are any specific instructions for changing the input source. Some devices may require a particular button sequence or menu selection to switch inputs.
- Power cycle the device: Turn off the device and unplug it from the power source for a few minutes. Then, plug it back in and turn it on again. This may help to reset the device and allow you to change the input source.
- Check the remote control: Ensure that the batteries in the remote control are working properly and that you are using the correct remote control for the device. Some devices may require a specific remote control to change inputs.
- Try a different input: If you're unable to change the input from the CD button, try selecting a different input button such as the radio or auxiliary input. This may help to reset the device and allow you to change the input source.
- Contact the manufacturer: If none of the above steps work, contact the manufacturer for assistance. They may be able to provide additional troubleshooting steps or suggest repairs or replacement options.
Hopefully, one of these steps will help you resolve the issue and allow you to change the input source on your device.
Does anyone have schematic for audiotrak 500 amplifier?
I don't have access to specific schematics for the Audiotrak 500 amplifier. However, there are a few options you can try to obtain the schematic:
- Check the manufacturer's website: The first place to look for a schematic is the manufacturer's website. Most manufacturers provide support documentation, including schematics, for their products on their website.
- Contact the manufacturer: You can also try contacting the manufacturer directly and asking if they can provide you with a schematic for the Audiotrak 500 amplifier. They may be able to provide you with the schematic or direct you to a source where you can obtain it.
- Search online: You can also try searching for the schematic online using search engines like Google or Bing. Enter the model number of the Audiotrak 500 amplifier along with the term "schematic," and you may find a PDF version of the schematic available for download.
- Consult with a professional: If you're not able to obtain the schematic through these methods, you can consult with a professional, such as an electronics repair technician. They may have access to the schematic or be able to assist you in troubleshooting the amplifier without the schematic.
I hope these options are helpful in your search for the schematic for the Audiotrak 500 amplifier.
I'm sorry, but as an AI language model, I don't have access to specific schematics for the Audiotrak 500 amplifier. However, there are a few options you can try to obtain the schematic:
Why won't my front speKers play on my avh 200e x?
There could be several reasons why your front speakers are not playing on your AVH 200EX. Here are some possible causes:
- Wiring issues: Check the wiring connections between the receiver and the front speakers. Make sure that the wires are properly connected and that there are no loose connections.
- Speaker settings: Check the speaker settings on your receiver to make sure that the front speakers are enabled and set to the correct size and frequency response.
- Balance and fader settings: Check the balance and fader settings on your receiver to make sure that the front speakers are not set to a low level or muted.
- Amplifier issues: If you have an external amplifier, check to make sure that it is properly connected and powered on.
- Speaker problems: If the front speakers are still not playing, there may be an issue with the speakers themselves. Check to see if the speakers are damaged or if the wiring connections are loose.
If none of these steps resolve the issue, you may need to consult with a professional or contact the manufacturer for further assistance.
