20 Most Recent
McCulloch 1400 Psi Electric Pressure Washerr#FH140A Questions & Answers
Mc Culloch power washer FH140A The "on/off"
easiest way to fix it, buy a new switch at a home improvement center, the two metal piece go on the bottom and the springs are on top of them, when the switch is in the off position the metal pieces are up off the contacts on the bottom and when on the on position the metal pieces make contact. Hope this helps Tim
McCulloch 1400...
Answered
on Jun 09, 2011
I have a McCulloch 1-Inch 1 HP 26cc 2-Cycle Gas
There are two things to check for. One, vaccum might be created in the tank only allowing the unit to run a few minutes. If it starts to die after running a few minutes, removing the gas cap. If it keeps running, you need a new gas cap. Otherwise your problem is in the carb. It could be bad gas that was in there before or you have debris in the carb itself which only allows the unit to run on choke. Make sure if you have a fuel shutoff valve that it is on.
McCulloch...
Answered
on Sep 18, 2009
Kohler DTV shower. Why is there erratic temperature control?
Run diagnostics.
Settings > System > Diagnostics
If no problem found, try System Reset.
Settings > System > Reset > Reset System > Cancel or Reset System
IMPORTANT!Resetting the system will return your interface to the original factory default settings. This will also delete any custom configurations or settings.
Plumbing
Answered
2 days ago
How can choose a touchless kitchen faucet?
The market is full of brands making these faucets but how to decide which one is the best suited to your needs. Below mentioned are few things which should be kept in mind while making a purchase of a
touchless kitchen faucets.
- Position of the motion sensor
It is important to check where the sensor is placed on your kitchen faucet. Their position varies from brand to brand. Some of them come with the sensor installed on their spout, while others have them at the bottom or the top of the faucet. It is up to you to select the one which suits your needs. Moen touchless faucets have two sensors, and the wave sensor is placed at the top which is responsible for the activation and deactivation of water flow and the other sensor, ready sensor is placed at the bottom, which is used merely for identifying the articles in your sink.
- Power Source
When it comes to a power source, there are two types of touchless kitchen faucets in the market. For the ones that need a continuous power supply you have to make sure that they are installed near a power outlet in your kitchen. The other type runs on a battery and can be placed anywhere. You can choose either depending upon your kitchen needs.
- Others
Before buying the faucet for your kitchen make sure its length, height, etc. is appropriate for your kitchen. Also make sure whether it is easily installable or not.
Plumbing
Answered
on Jan 19, 2021
