20 Most Recent Ingersoll Rand Air Compressor Maintenance Kit for TS7 Air Compressors Questions & Answers
I would like acquire all
Hello, Rdouglasv - Fixya.com does provide some repair and service manuals for a variety of items, but they are available because Fixya.com volunteers have uploaded those manuals for others to retrieve for free via Fixya. Fixya.com does not sell any maintenance / repair / service manuals. I did find a few web sites which sell some Ingersoll Rand repair / service manuals: http://industrialmanuals.com/ingersoll-rand-m-66.php and: https://airtoolpro.com/ingersoll-rand-service-documents/ You will find Ingersoll-Rand manuals to download for free here: http://powertool.manualsonline.com/manuals/mfg/ingersollrand/ingersollrand_air_compressor_product_list.html Note: The manuals are PDF documents and Adobe Acrobat Reader software (free) will be needed. Best wishes.
2/25/2018 10:03:26 PM • Ingersoll Rand... • Answered on Feb 25, 2018
Ingersoll Rand Air compressor loosing pressure
sounds like you have a problem with the discharge valve on the secondary cylinder, some I.R. pumps rely on the cylinder head valves to hold back tank pressure when the pump comes to a stop. the line down to the crankcase in front of the crank is a unloader valve that dumps the air pressure inside the pump to allow the next restart. I think that once you drain the tank and remove that cylinder head you will find a defective valve in the head.
6/26/2014 5:26:41 PM • Ingersoll Rand... • Answered on Jun 26, 2014
Did ingersoll rand make a
Hello. Yes. In fact if you wish to purchase one used, go to this site. It is about 5 down from the top. http://for-sale.yakaz.com/tow-behind-compressor
4 thumbs up please. ty. Joe
12/30/2013 6:02:31 PM • Ingersoll Rand... • Answered on Dec 30, 2013
0answers
2answers
Ingersol rand p185wir blowing compresor oil out air inlet
expect some oil in the air. I think you have too much oil in your machine OR your rings are worn.
11/29/2012 7:01:53 AM • Ingersoll Rand... • Answered on Nov 29, 2012
My air compressor show continusly the alarm NO CONTROL POWER
No Control power is often caused by high airend temp or a faulty High AirTemp. switch(IATS Switch i.e High Air Temperature Switch). I suspect the IATS switch is bad and opening prematurely/coolent level not suffecent or bad filter condition because the att. temp. probe located next to the switch is set to give a temp alarm and shut down the compressor at 228 degrees.The hat switch is located in the end of the airend and should have a 1/2 " flex conduit attached to it. When this switch opens it cuts control power and series to emergentcy switch having two NC connection but if press emergency it gives alram emergency but if you remove cable 36 inintellisys control pannel. Thus the controller issues a No control power . This switch is set to open at 245 degrees. If faulty it may open at 150, 180, 200. Anything but what it is set at. You can check this switch with a meter. When the unit trips simply test for 110 volts at the switch or in the control panel if familiar with wiring . please be very careful while in any electrical panel.. 110 volts in, 110 volts out. NO 110 volts out or on one leg of the switch means its bad and should be replaced.After it cools for a while the compressor will run again.
8/6/2012 4:53:37 PM • Ingersoll Rand... • Answered on Aug 06, 2012
Hello,how to fix ingersollrand p185 the problem
Please set your compressor to ' load' manually.
Regards, Jay
2/24/2011 2:54:25 PM • Ingersoll Rand... • Answered on Feb 24, 2011
Ingersoll rand air compressor P185
Hi, my name is John. Welcome to FixYa. You can get all you need to do the job here www.mastertoolrepair.com . Thanks for choosing FixYa.....John
12/3/2010 3:04:19 PM • Ingersoll Rand... • Answered on Dec 03, 2010
I want to increase pressure from 70 psi to 90 psi
by the pressure switch there should be a regutator whith a black knob on the top you will probably have to pull up on the knob to unlock it . then turn it counter clock wise. thi preessure ehould go up.
6/13/2010 6:23:21 PM • Ingersoll Rand... • Answered on Jun 13, 2010
3answers
I have a Ingersoll Rand P185 WJD air compressor
Do not use 30 wt oil. It will wreak the oil/air seperator filter. Use Ingersoll Rand Pro-Tec fluid. It will hold approx 3 gallons.
5/19/2010 2:57:55 PM • Ingersoll Rand... • Answered on May 19, 2010
What type of oil do you use for this compressor
1962?? if memoryserves me right the call for a 30w oil non detergent
4/21/2010 4:23:04 PM • Ingersoll Rand... • Answered on Apr 21, 2010
Wire size
I used to know all this stuff, the hardware store has a gauge guide to show you the correct size, i would guess that 8 would be ok, 10 would probably do it, hope this is right.
4/12/2010 4:45:36 PM • Ingersoll Rand... • Answered on Apr 12, 2010
Ingersoll Rand Air Compressor Maintenance Kit for TS7 Air Compressors Logo
43 questions posted
Top Ingersoll Rand Air Tools & Compressors Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
View Most Popular
  • Ingersoll Rand Air Tools & Compressors
Most Popular Question
ingersoll rand p185 wjd air compressor
  • Air Tools & Compressors
