20 Most Recent Hunter 20531 Vista Brushed Nickel Ceiling Fan Questions & Answers
There are several portions for a ceiling fan... it sounds as if the small motor that actually turns the blades shorted / or burned out.
Hunter 20531... | Answered on Nov 27, 2015
The ballast is still available on the internet, just Google "veb82122." They want $37 plus shipping. You can also but a 22W Circiline ballast at Home Depot that will work for about $18. (Lowes does not carry them). The original ballast is a solid state design, light weight and instant on. The Home Depot ballast is the heavy transformer kind and a real pain to modify the bracket to make it fit. I have 8 of these Hunter fans and I have installed the Home Depot ballast on two if them so far, but I think that I will order the solid state version as a spare for the next time.
Hunter 20531... | Answered on Mar 14, 2015
Make sure you have the correct wattage in the bulbs.
Hunter 20531... | Answered on Jan 24, 2013
There is a pull chain switch inside the fan termination housing. you will have to take the little cover off and remove the switch. it has 2 small screws with wire landed under them. Turn off the power at the breaker before working on the switch. take this little ****** out and put in a new one. you can get them at the Home Depot or equivelant. it don't matter if the new switch is a little bigger but it still has to fit. use some judgement here. wire it in the place of the old one, turn the power back on at the breaker and it should be ready to go. Presto.
Hunter 20531... | Answered on Oct 17, 2012
Hard to say for sure, but you find mored detailed information on evaluating the problem at this URL:
http://www.ceiling-fans-n-more.com/ceiling-fan-installation.php
In the listing on the left side you can go down to the information section on fan problems for additional help.
If you find this solution helpful, I would appreciate a Thumbs Up.
Be well. Paul
Hunter 20531... | Answered on Oct 05, 2010
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Hunter 20531... | Answered on Aug 13, 2010
mcdevito75 here, The lights should work from the wall light switch and the fan from the pull chain on the fan itself. The fan and the lights come off the same wall circuit so if the fan works, so should the lights, however in the fan assembly itself 1 wire was for the lights and 1 wire was for the fan. You'll have to pull the fuse to that fan, and remove the cover to the fans wireing at the ceiling., Now you can see the fans wireing, I'll bet the wire to the lights has fallen offf due to the vibration of the fan. Hook up the loose wire and the lights should work. If you can"t do the work, look for a handy man in your building / Area.
Hunter 20531... | Answered on Jul 19, 2010
I had same problem. The ballast is bad and I'm lloking to see if I can get just the ballast. I know the ballast is bad because I had an identical light kit that I hadn't installed on another light yet and used it to see if the first ballast was bad. It was. I suspect I (we) will have to get a new light kit. That kit won't be anything fancy, just something that will take a regular lamp.
Hunter 20531... | Answered on Jun 19, 2010
yep hardwars store easy one
Hunter 20531... | Answered on Jul 25, 2009
Okay. Turn off circuit breaker. Take the bottom off the fan. Mark how the wires are connected. Remove switch by unscrewing the sleeve you mentioned. Take the switch to Home Depot (or the like) -- buy a replacement.
If you have to turn the breaker back on during this process, make sure you have a wire nut over the end of each of the loose wires you disconnected from the switch.
After you take the switch out, you'll know how to reinstall it, so I won't go thru that.
Charlie
Hunter 20531... | Answered on May 12, 2009
Try chage the battery in the remote.If that don't do it then find the circult breaker to see if it is trip.
Hunter 20531... | Answered on Mar 14, 2009
buy a new fan
Hunter 20531... | Answered on Jan 18, 2009
Don't have a solution to this problem, but I'm having a similar problem. The remote works for the fan but the other day we had a light bulb burn out and ever since then the switch on the remote for the light will not work, but the fan works just fine. If anyone has a solution please post it or email me at [email protected] Thanks
Hunter 20531... | Answered on Dec 04, 2008
copper to green , white to white , seperate the black and the black with th white tracer you wired together connect the black to the black and the black with white tracer to the red in ceiling , without looking this is my best advise ,good lk
Hunter 20531... | Answered on Nov 27, 2008
Hunter 20531 Vista Brushed Nickel Ceiling Fan Logo
Popular Tags
28 questions posted
Top Hunter Dryers Experts
Paul Bade
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
View Most Popular
Hunter Dryers
  • Hunter Dryers
Most Popular Question
ceiling fan pull chain connected but not
  • Dryers
